E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > No rear pdc or reverse lights. Have already replaced switch.
      05-25-2013, 01:57 PM   #1
hbz
Drives: E91 LCI
Evenin, all!
I have a 2009 E91 318i LCI manual with (rear only) pdc and no i-drive.
My reverse lights and pdc are not working. When using the stereo audio settings I can access the pdc volume. The radio goes loud (odd) and then I can adjust the volume of the pdc beeps.
But, when I select reverse I get no pdc beeps and no reverse lights. My first thought was the reverse switch, which i have just this minute replaced with no luck and I'm gutted.
any ideas, gang?
Cheers!
chris.
      05-25-2013, 04:27 PM   #2
makkan00
makkan00's Avatar
Drives: F83 and F36
Fuse for reverse lights.
Fuse for reverse sensor module.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      05-26-2013, 02:25 PM   #3
AlanYoro35i
Senior Troll
AlanYoro35i's Avatar
Drives: Coming soon-718 Cayman S
Makky, can you tell me your coding software has the option to re-calibrate parking sensors??
Cheers
Gone:
N54 335i is the Legend!
N55 435i
Now: 718 Cayman GTS / F83 M4
      05-26-2013, 03:34 PM   #4
makkan00
makkan00's Avatar
Drives: F83 and F36
Cheers
You can reset the module but not calibration.
Whats wrong matey?
      05-26-2013, 05:38 PM   #5
AlanYoro35i
Senior Troll
Whats wrong matey?
Well you know my car has a wrap, i've been getting annoying parking sensors error. Sometimes the front works but the rear doesn't or vice versa. I got fed up aland removed the wrap on one sensor and i never had a problem lol. So yeah the car looks werid now with both jetwash cover gone and one pdc sensor is silver !!
Gone:
N55 435i
      08-18-2013, 03:43 AM   #6
hbz
Drives: E91 LCI
Bump....
I have replaced the reverse switch, I have tested both reverse light bulbs and have checked and tested fuses 7 and 63..
I couldn't remove the rubber boots going to the rear "hatch" but did try a good wiggle with the car in reverse and the ignition (not engine!) on.
Before I take it to the local "specialist", do you have any ideas of other simple fixes, gentlemen?
e90post
