Quick question regarding E92 passenger door panel removal & the Grab Handle "INSIDE"
05-21-2013, 10:28 PM | #1 |
Rep 549
Just forgot how to take the passenger door panel out
I know how to remove the driver side door panel with the DIY, do I need to remove the 2 screws behind the door grip handle on the passenger side? Thanks. Last edited by MAZINGER; 05-28-2013 at 12:25 AM.. |
05-22-2013, 02:27 AM | #2 | |
No 55mph
1622
Rep 8,476
Screws are under that trim
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
05-22-2013, 07:58 AM | #3 | |
Rep 549
I need to buy the replacement clip since the panel is loose now. Is there a tab on the handle outside access to the top and bottom screws or I need to pry the whole piece do the handle cover to gain access to the screws? Thanks. |
05-28-2013, 12:24 AM | #4 |
Rep 549
The black plastic piece behind the "Grab" handle starts peeling. It looks like the grab handle inside the "Coupe" is laminated to the plastic interior door panel (maybe I am wrong). As I know, the grab handles can be removed by unscrewing the 2 screws.
I would like to remove the whole piece of "Grab" handle to do vinyl wrap, is it possible to take it out? Are there any clips that mounted to the door panel that I do not aware of? Please help. |
06-21-2013, 08:43 AM | #5 | |
Rep 770
06-21-2013, 09:17 AM | #6 | |
Rep 549
However, the top and bottom portion edges will not 100% protected and perfect from peeling again due to touching the door panel leather / vinyl skin of the door panel. The sides should be okay because the vinyl piece rolled back behind the door grab cover. |
06-21-2013, 09:23 AM | #7 | |
Rep 770
06-21-2013, 09:38 AM | #8 | |
Rep 549
The most efficient way is to vinyl wrap the plastic piece behind. |
06-21-2013, 10:34 AM | #9 |
Rep 770
Yeah im going to do the same..have some wrap coming next week
