05-20-2013, 02:50 PM | #1 |
Rep 218
DIY: Velcro the rattles away.
Hi guys,
If you're like me, then you absolutely hate rattles, why? Simple, it makes your car sound old... old as your grandfather's F150 pickup truck, which to your disgust rattles less than your brand new BMW. Now lets be clear on something, this is not a miracle guide, this is not professional work. This is what you can do today instead of browsing hot Asian chicks or whatever you folks do these days. And to finish up my introduction, never ever never go to the dealer for these issues, they don't have the time nor dedication to fix the exact rattles that your car has, they don't know where they come from... but you probably do, don't you? Okay first step! Get the velcro! you will only use the soft part, make sure its thin, not too thin.. but you know, thin. You can also get white and black velcro.. depends how pro you wanna go. Cut the Velcro in small bits. Without looking too much at my disgusting fingers, wear down the adhesive a bit so it slides down more easily (if you know what i mean). This next picture shows my capable hands sliding the velcro in between the door panel and the door with a Thai hotel card i stole some time ago... ohhh the memories. The result should look like this, don't slide it in too much because the door panel border is only about 5mm thick. I strongly recommend you apply the velcro to these areas, same goes for the back doors. Next lets go through some parts that i've found can cause lots of rattles, the first culprit is this motherf***er: --It actually had dug into the other piece of plastic because of all the movement down there.. WTF BMW??!! ( Pardon my french ) You can find it in the footwell-passenger side.-- Same place, same story... freaking plastic loves to rub together The three points are where i found the noise comes from, try to stuff some in and watch for results by poking both pieces with your finger. Now to the grand finale, the Motherubbing piece of trash beneath your AC panel.. who designs these things??! --As to how you can pry that thing off, put your lady fingernails in the top side of the cover, don't use any metal tools! Its comes off pretty easily. Start from the top then the bottom slides out, paste velcro on the tabs that hold the cover against the front of the panel.-- Finally some other places where you could potentially eliminate a rattle: The side skirts are another story, this can be either done by your dealer, which will require some time as the skirt clamps break when you remove them, they have to order new ones but it should be done under warranty. OR! just slide some velcro and see if that works. And you sir.. Are done! Now remember this will only fix 50% of the rattles, the rest is up to road conditions, tire pressure and profile, how much you slam your doors ( ladies are experts at soldering my passenger door when they get in... and noo i wont unbuckle, pull handbrake, press P, open door and go around the car just to close it for you.). In any case, it wont require any disassembly and its a quick fix that will last. If any of you are worried about putting extra pressure on the door panels, remember the doors are assembled tightly... that pressure is lost with time and movement. Last edited by Koer; 07-15-2014 at 04:20 PM.. |
05-20-2013, 03:55 PM | #2 |
Rep 1,975
Man, my driver's side headliner just to the left of the visor and left of the microphone rattle like a biotch. Do you have that rattle?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
05-20-2013, 04:23 PM | #3 | |
Rep 218
05-20-2013, 05:02 PM | #4 |
Rep 1,975
Cool, thanks. I'll eventually take it in, I just don't want to be without my car for a day. When it rattles bad, you can just apply pressure to the headliner and it goes away but who wants to drive while pressing the headliner, lol
05-21-2013, 10:25 AM | #6 | |
Rep 218
They removed the loose parts and put them on again.. Without putting in any insulation, this meant my car rattled even more because parts loosen up every time you remove them! Glad it helped |
05-21-2013, 05:26 PM | #7 |
Rep 5,373
OMG, is BMW NA reading this forum?!?!?
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
05-21-2013, 10:30 PM | #8 |
Rep 169
Entertaining read. Thanks Seriously, for a $40-$50k vehicle, this type of rattle problem is not acceptable. Why haven't BMW thought of putting some kind of thin foam inserts serving the same purpose as the velcro? Crazy.
05-22-2013, 12:11 AM | #9 | |
Rep 218
05-22-2013, 02:56 PM | #11 | |
Rep 218
Mexico's roads are the worst, worse than any other third world country i've seen, so my car rattles like crazy. (2012 build 335) Maybe you just got lucky, or maybe your roads are stupidly smooth! |
05-22-2013, 09:23 PM | #12 |
Rep 26
Great post. Thanks!
I have an annoying rattle that seems to come from the steering column. Has anyone dealt with this one and managed to find a fix? It's a 8/2012 build 335i. |
05-23-2013, 02:31 PM | #14 | |
Rep 218
Chances are its the foamy column underside cover, put some paper between it and the column's plastic and see if there is any change. Other solution is to try different column positions. Up down or towards you. |
05-23-2013, 02:32 PM | #15 | |
Rep 218
12-15-2013, 10:01 PM | #16 |
Rep 3,893
fun read! wish I read this 7 years ago...I could've helped my buddy out with his 330 e46 zhp ... it rattled like it was born to rattle
07-14-2014, 11:57 AM | #19 | |
Rep 218
07-18-2014, 09:26 AM | #22 | |
Rep 218
Just need some time and encouragement. 😁 |
