MAP sensor not seated proper
05-20-2013, 06:42 AM | #1 |
Rep 2,048
The manifold absolute pressure sensor is located on the inlet manifold and is held on/in via a rubber grommet like a push fit.
This time last year I had an issue with hesitancy at low revs and I was advised to change the MAP sensor and grommet (which I did) and partly solved the problem However I was checking my car for fault codes and 41aa boost pressure too high came up which was the same code related to MAP sensor last year. I had a look at the sensor and feels very loose inside the grommet so not sure if it is making a tight seal - Would I be able to use something like gasket/silicone sealent to seal the grommet/sensor in place? or would this not be advisiable? |
05-20-2013, 07:09 AM | #2 |
Rep 3,866
05-20-2013, 07:13 AM | #3 |
Rep 8,970
If its like the 335i one, its possible for the o-ring to get trapped or dislodged and not seal properly.
When you fitted it did you put a little light oil on it so the sensor & o-ring would slide in without getting 'nipped'? If not, I'd just get another o-ring and re-fit it. External sealants etc are always just a bodge, avoid, especially on a pressure system. |
05-20-2013, 11:23 AM | #4 |
Rep 2,048
BMW replaced it last year for me so I wouldnt know if they put a little bit of oil, but wiggling it around it does feel loose - surely the rubber grommet doesnt break down that fast?
I may just take it back out and clean sensor with electrical contact spray and refit - will order a new grommet tommorow thanks for the heads up on using silicone sealent i wont use that |
05-20-2013, 12:56 PM | #5 |
Rep 2,048
Had a look earlier on took the sensor out, I had to use a screwdriver to lever it out so it was seated in. The sensor was slightly covered in oil so used a switch cleaner (tip dont poke a pin in the hole ) as this can damage the sensor, checked the grommet which was fine - re fitted, made sure i pushed it in fully. There was some grease around the grommet so I presume BMW did use some
cleared the the 41aa/41ab code and took it for a drive and can definatly notices the improvement - no hesitancy at low revs |
