05-13-2013, 06:58 PM | #1 |
Rep 36
Strange stuttering after starting the car sometimes.
Recently I put in an AFE intake and scorcher on my 328i sport line. Everything seems OK but sometimes when I start the car the engine seems to stutter/rumble for about 2-3 seconds. It's pretty scary and the tachometer will fluctuate up and down during these 2-3 seconds. After that it settles down and the car appears to be perfectly fine. Its happened 3-4 times already and I'm worried one of the AFE mods might be damaging something. Any ideas? I don't know much about cars.
05-13-2013, 09:37 PM | #2 | |
Zooombie attaaack!!
136
Rep 1,179
05-13-2013, 09:55 PM | #3 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
Reset your car to stock & test over a few weeks. If all is ok, then introduce one aFe mod at a time & test. Hope you find a solution.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
05-13-2013, 11:40 PM | #4 |
Rep 36
05-14-2013, 01:15 AM | #5 | |
Rep 336
Drives: 2012 328i
05-14-2013, 10:06 AM | #7 |
Zooombie attaaack!!
136
Rep 1,179
05-15-2013, 12:26 AM | #9 |
Usofstance
78
Rep 671
normal, In Europe they dont have this issue cause because the fuel their is cleaner.Main reason to the idle issue and not only do bmws get it but audis,volkswagens etc. Info via a master tech.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance United States Of Stance |
05-30-2013, 08:13 PM | #14 |
Rep 32
Not sure if its the same. Just happened to my car
Stalled once, rough idle rpm fluctuating. Car attempts die sitting idle. Turned out 2nd cylinder injector at fault More fuel than needed spark plugs burnt. Both replaced at dealership took five days to get parts All good now finally. |
06-03-2013, 02:00 PM | #16 |
Rep 88
I just noticed in the past week or so, when I turn on the engine from an overnight parking and start to go right after, the car "surges" forward, feels like it has a small amount of "explosive" forward momentum, it's hard to describe, it's like it's on race gas boost or something.... It "jolts" forward, would be a more appropriate description... It goes away after about 20 sec of driving, but this jolting started happening recently.
I wonder what's going on?? |
06-05-2013, 07:41 PM | #17 | |
Rep 80
Slightly off topic, but how is the AFE kit working? Are you getting a noticeable boost? I am just waiting for some mad money to come in so that I can buy the intake/scorcher combo. |
06-05-2013, 11:33 PM | #18 | |
Rep 36
I had the bms stage 1 tune before this and when I took that off I put both the afe scorcher and intake on at the same time. The main noticeable difference is that the engine is louder, there's a hearty rumble from it when I accelerate. The boost feel is pretty similar in both cases. Maybe faster in comfort mode for afe and faster in sport mode for bms. I liked both and just wanted to try something different. I don't have any real stats to back up what I said though but you'll definitely be happy with the combo. |
07-30-2014, 11:21 AM | #19 |
Rep 274
I just posted a thread about this. my car is stock, and it seems to be kinda rough or chattery at cold start sometimes, then smooths out. guess this is normal? anything to do with the turbo spooling up?
08-01-2014, 04:58 PM | #21 |
Rep 300
I get this first start in the AM almost every day with no intake. If you feel it is really severe, try taking the intake off to see. The intake could also be messing up the MAF and amplifying the issue.
Jim |
08-18-2014, 06:29 PM | #22 |
Rep 205
Something similar happened to my car last week, but much worse.
The car would start and studder heavily and die after 5-10 seconds.. Happened 4-5 times in a row. I tried to get some life into it by pressing the accelerator, which only killed if faster. Anyway tried it one more time and this time reving it a bit helped, and all was back to normal. I have no clue what this was about, only happened this one time. But the reason could be that I was up in 6000ft above sea level and my airfilter was probably a bit dirty from driving on a dirt road. The car is completely stock |
