E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Window tint + rust around brakes
      05-13-2013, 12:13 AM   #1
RRebelo
Drives: E92
Hi,
Currently I have a black e92 335i and want to tint it with 35% or 20%. Any good shops around Seattle/Bellevue?
I already saw some tinted windows where we almost don't notice the "strip" (lighter near the dots) around the window and in others its very noticable. Any ideas why?
Another thing is that I have some rust around brakes/not sure the same of the piece where the wheels are fitted. Any good place to remove it?
Thanks,
Ricardo
      05-13-2013, 01:28 AM   #2
Amini77
Drives: Alpine White '13 550i
2013 BMW 550i  [0.00]
I think you're talking about the hub. I've seen people paint over it with silver looked pretty good.
      05-13-2013, 12:50 PM   #3
McAuley7
@McAuley7
McAuley7's Avatar
11
Drives: 2010 335i
2010 335i  [9.00]
Yeah the wheel hub probably I hav it on mine people say use steel brush on power drill I did took off a little , if ur taking about the rotors they have some good brake/rotor cleaner at autozone for $3 works good
      05-13-2013, 12:51 PM   #4
RRebelo
Drives: E92
That's it - the hub TKs.
Any good shops for window tint around Seattle?
      05-13-2013, 01:20 PM   #5
Pete Schweaty
Pete Schweaty's Avatar
39
Drives: 2014 750li
Take the wheels off. With a wire brush or wheel in a drill grind it all off and paint it. Then smear a little anti seize onto the hub face being careful not to get it in the bolt holes. This will also fix the problem of the wheel seizing to the hub. If you have never taken the off before, you will probably need to knock them with a rubber hammer. When I did mine, I brushed everything. I have heard that you can spray it all too as long as you tape everything.
      05-13-2013, 08:11 PM   #6
RRebelo
Drives: E92
Thanks for the pictures. That's exactly my problem but although I like to do this by myself, for this I will need to do it on a shop (no space, tools, etc.).
Any good shop for this kind of work?
e90post
