E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > How difficult is it to install e92 LCI tail lights?
      05-12-2013, 10:33 AM   #1
miringrains
Drives: '11.5 M3 E93
I've been looking for a write up, and I cannot find one. I have a 2010 e92.
      05-12-2013, 12:17 PM   #2
stimpy
Drives: E92 335i
Beyond easy.
3 bolts and a wire and they slide right out and you'll repeat the steps for the LCI tail's but with an additional step of connecting an additional wire harness into the existing and then that into the tail lights.
You'll probably need to do mild adjustments to the new lights to make them flush with the three bolts and little knobs but it's very simple.
      05-12-2013, 02:31 PM   #3
ChasVS
ChasVS's Avatar
Drives: 2012 MB ML350 Bluetec
Isn't a 2010 an LCI model? Or do you mean LED Tails? Those would fit just like existing tails, but would need coding after installation.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
      05-12-2013, 03:04 PM   #4
Ohai2uFTW
Drives: x
2010 and under = pre, 2011 and up = lci.
I'm also looking for a write up or solid info thread actually. Good timing.
So in a pre-lci e93, all you need to do is order e93 lci tail lights, and they fit perfectly and all? What is this wire harness that you are talking about? Also I heard that some kind of coding needs to be adjusted to fix an error that comes up.
      05-12-2013, 03:12 PM   #5
patman5300
patman5300's Avatar
Drives: 2008 335i e92 SGM 6MT FBO
Installation is pretty easy, less than 10 minutes. 3 bolts on each side. Just have to get it coded otherwise the turn signals will hyperblink and lights will randomly strobe on startup.
      05-12-2013, 03:31 PM   #6
Game
Game's Avatar
Drives: G87 M2 (sold)
Simple swap, direct plug in, then coding.
      05-12-2013, 03:55 PM   #7
Ohai2uFTW
Drives: x
Where's the best place(s) to buy e93 tails?
What does the coding involve?
e90post
