2013 328i harder pull then my 335?!
05-09-2013, 12:12 AM | #1 |
Rep 96
My 2007 335 was in the shop due to a bent wheel, so they gave me a 2013 328i as a rental car. For some reason when I floored it the pull on the 328 felt stronger then my 335 weird huh? Anyone know what can be the problem?
05-09-2013, 12:14 AM | #2 |
Rep 1,463
05-09-2013, 12:15 AM | #3 |
I don't drink water. Fish fuck in it.
45
Rep 865
Drives: e90 335xi
Location: Some say he naturally faces magnetic north, and that all of his legs are hydraulic...
sounds like theres a reason your 335 is in the shop
oem blacklines, m3 rep front. waiting for install oem m3 sides... coming soon. csl trunk mtech rear and more. |
05-09-2013, 12:16 AM | #4 |
45
Rep 865
Drives: e90 335xi
05-09-2013, 12:53 AM | #7 |
Rep 1,720
Well isn't the 328i extremely underrated out of the factory? I thought it was putting out around 270 at the crank. Still, 335i *should* be faster.
Current Ride: '16 MK7 GTI//
Former Ride: '06 E90 330i// Don't mind me... just passing along// Old E90 Thread: http://www.e90post.com/forums/showth...first+e90+m580 |
05-09-2013, 02:59 AM | #8 |
Rep 1,465
328i has a 4 cylinder turbo mated with 8 speed. That surge of power is attributed to the fact it has an 8 speed, lower gear ratios, giving you that feeling it's faster.
Your 335i actually is faster than the 328i no matter what. Even by BMW specs, n54 335i does 0-60 in 5.0, 4cyl turbo 328i does 0-60 in 5.9. I had that feeling when I had the loaner at first, but then I realized it was not as good in the top end. Then when I got my 335i back from service, I can definitely tell the 335i was more planted and had better power output. |
05-09-2013, 03:20 AM | #10 | |
Rep 4,732
Drives: Alpine White '13 550i
It's just the feeling of a different car you think it's faster. Probably because you're used to the way your car feels. Also the F30 has a 8 gears so more gear changes=effect of going faster according to Fast and Furious.
Anyways AWD feels slower because during a roll, all 4 wheels are giving effort to spin so you can't really feel it (not as many G's I guess) as opposed to RWD you can feel the rear wheels lock down and pull since all power is at the rear. That's just what I assume why RWD feels faster. |
05-09-2013, 03:24 AM | #11 | |
7422
Rep 10,223
05-09-2013, 03:29 AM | #12 |
Rep 4,732
05-09-2013, 05:52 AM | #13 |
Slightly modified...
13
Rep 289
I couldn't get past the new gearing ratios. The 328 loaner I had was nearly 3k on the tach as I approached 40 in 3rd gear. 4th gear was over 4k at 60
My car is at 4k at 60 in 3rd gear.. Just felt weird. I guess I like the taller gears in my '07 |
05-09-2013, 05:57 AM | #14 | |
Came to the N55 Darkside
1113
Rep 12,740
05-09-2013, 05:57 AM | #15 | |
1113
Rep 12,740
05-09-2013, 10:04 AM | #16 | ||
Rep 96
05-09-2013, 10:54 AM | #18 | |||
1113
Rep 12,740
