2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N20 0-60 roaster
      04-19-2013, 09:03 PM   #1
JohnnyF10
Drives: f10 528i xDrive, e93 M3
N20 0-60 roaster
Hi, I am trying to see what is you 0-60 time, stock and tuned
This is only for 5 serie
2012 F10 528ixDrive | Vorsteiner Front Lip & rear Diffuser | 20" MS50 MORR Wheels| M5 Grill | M5 Spoiler | ACS Roof Spoiler | ACS Spring | Arqray Quad Exhaust | Hartge Tune
2011 E93 M3 | Vorsteiner Front Lip & rear Diffuser |19" ZCP OEM Wheels | Black Grills | CF Trunk Spoiler | Alcantara Boots | BMW CF Trims | Akrapovic CF Exhaust
      04-24-2013, 11:27 PM   #2
RambleJ
RambleJ's Avatar
Drives: F10 535i M-sport
7 seconds, to 6.5
      04-25-2013, 08:07 PM   #3
JohnnyF10
Originally Posted by RambleJ
7 seconds, to 6.5
What is your tune! Do you have an xDrive ?
      05-04-2013, 12:01 PM   #4
wifesbimmer
Drives: '20 X5 M50i, E92 M3, '16 F150
I haven't timed mine yet.
      05-04-2013, 12:04 PM   #5
wifesbimmer
but I would like to ask you a question in regards to a couple of mods you've done since I have exactly the same car as you. Is the rear diffuser you've put on to mount the quad exhaust simply a replacement? Do you dismount the original peice and mount the aftermarket one on? How does that work? It would be greatly appreciated if you help.
Thanks
      05-04-2013, 02:59 PM   #6
JohnnyF10
Hi,
As for the diffusor, it is just a replacement on e insert in the M bumper. No cutting, no fabrication it is really made to be there. Vorsteiner products are perfect fit.
For the exhaust, you know that or the right end side of the trunk, our cars, 528, we have a compartment that is deep compare to a 535 or 550. So you will not be able to put a normal exhaust since there it no space. I have opted for Arqray and they have made a system with dual exhaust where the one on the right side is small and will fit without any modifications. I believe only them and eisenmann offer a solution like this. All other will have the modify your trunk compartment.
My exhaust sounds almost like stock, it is not loud and I am very happy with it as I didn't want the car to sound like a civic. No drone whatsoever. If you want a big rumble, this exhaust is not for you. I have posted a sound clip of the exhaust. If you do a search on my name, you will find a series a photo and a sound clip.
Hope this help
      05-04-2013, 03:14 PM   #7
wifesbimmer
another question if I may.. you said it's just an insert in the M bumber. What if I don't have the M bumper? Does that mean I have to buy a M bumper from BMW with the insert?
      05-04-2013, 07:46 PM   #8
snj1013
Drives: 2011 528i
Yes you need the M Sport bumper to use any of the factory BMW diffusers.
If you like the quad look, you can keep your existing bumper and cut the right side to match the left, or there are a couple of aftermarket diffusers that can be fitted to the non M Sport bumper. These also require cutting I believe. Hamann makes one you might want to look at.
      05-05-2013, 09:07 AM   #9
saeba1
saeba1's Avatar
Drives: 2015 F82 M4 DCT
Originally Posted by JohnnyF10 View Post
Hi,
Hope this help
I can confirm the need to replace the right trunk compartment.
I had mine replaced with the shorter one from a 535. Once that is done, you can use a regular exhaust/muffler such as the one made by Meisterschaft.
2015 F82 /// M4 DCT - BBS FI-R | Macht Schnell EVC | Eisenmann Performance | RKP GTS Lip | RKP Diffuser | IND Cosmetic Package | CF Seats Cover
2012 F10 528i xDrive - BC Forged HB05S | Meisterschaft GTC | 3D Front Lip | Vorsteiner Diffuser | MP Mirror Covers and Spoiler | ACS Springs
      05-08-2013, 12:37 PM   #10
wifesbimmer
thanks for such informative help guys
      05-15-2013, 05:54 PM   #11
JohnnyF10
With 20'' 6.43 stock and 6.07 tuned with Hartge
