BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      04-19-2013, 11:21 AM   #1
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
Vorshlag Install
How many people are actually trimming this piece as outlined in the Vorshlag instructions? If anyone is, do you have before and after trimming photos of the piece? Thanks.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
      04-21-2013, 02:42 PM   #2
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
Since nobody seems to have installed these themselves to comment, here is a picture of mine installed after trimming about 3/16" all the way around the ID. The picture in my first post is a little confusing until you get the whole thing apart. The picture on the Vorshlag instructions shows them untrimmed, and I honestly don't see how this helps, but I did it.
Also, I sure am getting a lot of noise over hard bumps or quick compression of the suspension. Anybody experience this with the switch from EDC ZCP setup? I am using stock coils. Camber is at about -0.9 degrees until I can get it done properly.
      04-21-2013, 03:07 PM   #3
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
I didn't do my install but we didn't trim it. May add slightly to stack height?
m3post
