F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Will adding H&R coilovers void my BMW warranty?
proTUNING Freaks
      04-09-2013, 11:22 AM   #1
Demetrius Joel
Drives: 2014 BSM/CR M235i
2014 BMW M235i  [0.00]
Will adding the coilovers void my warranty? Also will adding them affect my M Adaptive suspension, meaning will I still be able to use my different settings from inside my car?
      04-09-2013, 12:00 PM   #2
1bad335
Drives: 2007 335I/ 2012 335I sportline
They can only void your warranty if the install of the part/s is directly attributed to the failure you are requesting warranty work on. If you are claiming a steering issue and BMW attributes that problem to be linked to your install of coil overs , then they can deney coverage. Keep in mind all other warranty coverage remains in effect. They can not, by law void your entire warranty because of any installed aftermarket part. Here is a long read but sums it up.
http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
Just realized you are in Germany. Check your local laws.
      04-09-2013, 03:39 PM   #3
Demetrius Joel
Thanks for the clarification. I'm in Germany but I have a US spec vehicle. I'm in the military. My warranty is under BMW USA.
      04-09-2013, 06:36 PM   #4
1bad335
You should not have any issues. Thanks for your service.
f30post
