E90 charge point?
03-29-2013, 06:06 AM | #1 |
Rep 77
E90 charge point?
Anybody got a picture of the location? I can see the red plastic positive point to the left of the engine but where is the negative point?
Wanting to use a CTEK conditioner. Last edited by inkey$; 03-29-2013 at 06:24 AM.. |
03-29-2013, 06:52 PM | #4 |
Rep 4,528
Save your money and by an optimate.
Comes with a few different interface leads that you can pre install to create a plug in charger. Had one for 10 years + for cars and motorbikes and never had any issues. |
03-30-2013, 04:33 PM | #5 |
Rep 77
03-30-2013, 04:38 PM | #6 |
Rep 77
Does this also mean my E90 has an always live cigarette lighter under the centre armrest?
04-10-2013, 11:25 AM | #7 |
Rep 4,528
Inkey,
Unfortunately not. What I've done in the past is either :- 1. install supplied leads direct to the battery terminals in the boot, tucking the plug in connector out of sight but accessible w/o having to remove battery cover. OR 2. buy an oem charger socket and mount it in the boot and connect via fused leads to the battery as above and then use leads you can buy with male to fit the above charger socket. Advantage of # 2 for me was 2 fold:- a. I have the same charger socket on my bikes so can use charger c/w above male adaptor on all my vehicles. b. provides a direct fused power socket in the boot not linked to ignition. Both the above options, the charger leads are slim enough to allow the boot lid to be closed and leave the car secure whilst battery is being charged or conditioned. Last edited by Bee Pee; 04-10-2013 at 11:26 AM.. Reason: correct typos |
04-10-2013, 01:50 PM | #8 |
Rep 408
on the point of charging, can anyone tell me absolutely that the charge points under the bonnet are directly linked to the battery? or can the charging get cut when the car goes to sleep? I have read varying comments on the topic.
04-11-2013, 02:17 PM | #9 |
Rep 4,528
335ier
Charging points under the bonnet are not linked to ignition etc ie if put jumper or charger cables onto them then will pass the charge to the battery. |
04-11-2013, 02:23 PM | #10 |
Rep 228
ive got a ctek charger conditioner ,very good and I recommend
Ive only used it once on the bmw the rest of the time it goes on my classic car I attached it to the charge point under the bonnet (with the red plug/cover near the drivers side suspension turret top)and the neg to the nearest earth (turrettop suspension bolt) |
