03-19-2013, 06:33 AM | #1 |
BimmerPost Supporting Vendor
4912
Rep 115,980
328i JB4 (Stage2) E85, 13.0@109 Run
Some more updates for the Stage2
BMS was out doing some VBOX testing with the 328i. 0-60 in 4.6s and a best 1/4 mile time of 13.0@109. Knocking on 12s door. The car is still completely stock other than the JB4 and E50 fuel. This was using map 7 which peaks at 23psi. They are planning to do some pump gas dyno testing later this week. |
03-19-2013, 06:53 AM | #2 |
Rep 176
Looks good Mike! Can't wait!
2019 Ibis White/Red S4
1997 Nissan Skyline GTR V-SPEC Last edited by Turboedv6; 03-19-2013 at 11:17 AM.. |
03-19-2013, 06:40 PM | #4 |
Rep 886
Awesome results!! Throw on a turbo-back exhaust and some better tires and you are EASILY in the 12's!
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
03-19-2013, 09:23 PM | #7 |
Rep 176
I'm sure he was in sport mode, unless he was going for most mpg in a 1/4 mile.
1997 Nissan Skyline GTR V-SPEC |
03-19-2013, 09:30 PM | #8 |
Rep 3,780
The modes are indistinguishable at wot, so you can dyno in any of the the modes and make the same power. So if your are flooring it, it does not matter.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
03-19-2013, 09:35 PM | #9 | |
Rep 176
I know, it was just a failed attempt at humor.
03-19-2013, 09:37 PM | #10 |
Rep 185
03-19-2013, 09:40 PM | #11 |
Rep 176
03-20-2013, 03:52 AM | #15 |
I plead the 5th.
523
Rep 1,519
It's only a matter of time!
I vow to dyno within a week of receiving this tune. If I'm lucky, BMS will need an N26 for Beta
-Matt
03-20-2013, 04:35 AM | #16 | |
Rep 176
I'm going strait to the track fueld by C16 and maybe some LOL gas.
03-20-2013, 06:05 AM | #17 |
4912
Rep 115,980
03-25-2013, 06:28 PM | #18 |
Rep 182
03-25-2013, 08:48 PM | #19 |
Rep 2,431
Hey terry,
If you need a beta tester for the n26 lmk. I can do irwindale runs for the 1/8th times. I beta tested your n52 and n55 tunes! And ill dyno it at eas
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
08-07-2013, 09:34 PM | #20 |
Rep 688
Wanted to resurrect this post because I found it interesting...was this car a manual or auto? I'm curious to see updated VBox figures as well. I'm sure the Stage 2 tune has been tweaked a bit since March, so that alone should be good for 12s at 110+. With a turbo-back on top, this setup should move.
I'm curious what the limiting factor is for testing on a higher mix of E85. Is straight E85 in the tank out of the question or perhaps too risky for the fuel-system? |
08-07-2013, 11:15 PM | #21 | |
Rep 886
To get to the desired 100oct to run Map7, I mixed my 91oct with 45-50% E85 (~105oct) as recommended. I can't speak for the N20 engine, but the N26 that I have will not successfully work with a 45-50% E85 mix while close to or at WOT. The engine hesitates, studders, and bogs down. To troubleshoot at the time, I switched to Map2 and then Map1, all Maps had the same problem. Once I filled up again, I blended my 91oct with enough E85 (roughly 15%) to get to 93oct so I could run Map2. Once I did this, all problems went away...this applies to Map1 as well. In the future, if I would like to run Map7 again, I'll have to fill up with 100% (traditional) 100oct.
08-07-2013, 11:32 PM | #22 | |
Rep 1,591
For my own records, I ran a baseline on my 335i a couple weeks ago and installing BMS Stage 1 tomorrow then throwing it back on the dyno. Planning on recording any upgrades as I go along so that I can see the differences as well. I'll post up charts tomorrow night when I get them from EAS. Not looking for Molly, then? LOL
-JustinNApproved
