Buying a used pre-lci e92 335i coupe, what to look for?
03-11-2013, 08:15 PM | #1 |
Bit by Modbug
255
Rep 1,109
Have my eyes on a few 335i coupes with around 30k miles on it, they range from 2008 to 2010.
What should i check when i see the car in person? If the car still has a year warranty, should I still get an inspection done? I noticed a few of the ones I looked at had a ticking noise in the engine bay and did some googling on that, and most people say it's normal? True fact? Thanks |
03-12-2013, 07:54 AM | #2 |
Rep 1,903
Drives: e92 335i 6MT
First, get the full warranty history and CarFAX or similar report. You can do an independent inspection if you're not fully comfortable checking the car out by yourself. Check to make sure all the recalls are done (ie HPFP, latest ECU data etc). Also, see what the maintenance schedule is indicating in the i-Drive / cluster.
Most important thing is to check condition of the turbos. Wastegate rattle is common on these cars and can be a nuisance. You can find videos on youtube of what that sounds like. Also confirm, you don't have excessive smoke coming out of your exhaust, which can be a sign of blown turbo seals. Otherwise, test drive the car thoroughly and check each and every single feature on the car |
03-12-2013, 01:47 PM | #3 |
Bit by Modbug
255
Rep 1,109
If there are recalls that arent done, but it's still under warranty, would I be able to get the recalls done myself?
It's getting inspected as we speak, I did some minor inspections and the only problems i found were the cupholders are somewhat stuck, and the engine makes a ticking noise when I was parked with the windows opened. I went to the dealership to test drive another one with the same model year and it didn't have the ticking noise, but I asked the salesman about the ticking noise they said it is completely normal for some to have the ticking noise. Thanks |
03-12-2013, 02:17 PM | #4 | |
Rep 1,903
The ticking noise is totally normal if it is related to the high flowing fuel injectors. Personally, I've heard all 335s to have it and it is most apparent at idle, especially windows open. |
03-12-2013, 04:31 PM | #5 | |
Rep 473
335i Space Grey Coupe/ppk/ssk/pe exhaust/perf susp
03-12-2013, 07:18 PM | #6 |
Bit by Modbug
255
Rep 1,109
Thanks for the great info guys.
Inspection came back and the car seems pretty good, they noticed the ticking noise too but apparently it goes away after the car is warmed up. Either way, I will have to look at the car in person again and do some negotiating and hopefully get a smoking hot deal. |
03-13-2013, 09:52 AM | #7 | |
Rep 2,202
http://www.e90post.com/forums/attach...1&d=1269307041 Or these big thick black lines under the hood right between the engine and fan http://www.bimmerfest.com/forums/att...hmentid=102689 That will tell you if the car has an oil cooler. This is a five figure job for someone whose unskilled at DIY work. |
03-13-2013, 07:20 PM | #8 |
Bit by Modbug
255
Rep 1,109
Thank you for the help, I bought it
It has the vent by the right side wheel well. Paid BCAA to do a full inspection and 90% of them are good, just a few body dings and wheel scratches. There are little white spots in the engine bay though, I wiped them off easily, what are they? |
03-13-2013, 07:29 PM | #9 | |
Rep 3,780
Drives: 330i, 135i
04-05-2013, 05:29 PM | #11 |
Rep 23
You should be able to request for the car's maintenance history from the dealership. I was able to trace my car's recall records. The fuel injectors, high pressure fuel pump, and low pressure fuel sensors were all replaced at the same time. I just received the recall notice for the battery cable a few days ago and have made an appointment to have it done. Congrats on the new ride!
