BMW M3 Forum (E90 E92)
      03-10-2013, 07:55 PM   #1
mikefromMA
Drives: 2017 m4
2017 BMW m4  [0.00]
2015 428  [0.00]
I've researched this topic and thought after many unsuccessful attempts, I'd hopefully be able to help someone else out there wondering what shark fin can be used, how to remove it, how to replace it, and what the process looks like in a simple DIY.
The damaged fin has a scratch and is the one with the black residue not the lighter gray residue.
Unfortunately, uploading the pictures was an issue, but at least I can explain the process and you can reference them if necessary.
1.) Find a replacement fin - I'm not sure if I can identify where I got the fin from, but just check an online junk yard for high class vehicles (...new was ~$150 from bmw, I paid $50 for a 2011 oem). All e9x series fins are the EXACT same and regardless of what options you have/want i.e. bluetooth, sirius, etc the housing still is a constant.
2.) Removing broken/original fin - grab some fishing wire and just separate the fin from the roof. It's very simple, there's no chance of damaging anything, you're simply breaking a seal of 3m automotive tape between fin and roof.
3.) Cleaning old residue off roof - I used alcohol and little diluted goof off. The clear coat is pretty resilient, especially on the roof so don't be afraid to opt for the diluted goof off. I didn't use straight goof off, as I didn't want to test the limits on the clear coat of a $5000 roof. Also, a blow dryer can help in the process. I live in the Boston, so the weather does not cooperate when removing any type of adhesive.
5.) Apply extra strength 3m tape (you can get it at lowe's, home deport, autozone) to all contact areas of new fin. I poked the 3 positioning points through paper, drew the margins, and then placed parchment paper over the paper so I could place the 3m tape over the margins and cut with a razor blade in order to prep the 3m tape. Whether or not you want to use this method is up to you. I found it to be very easy and user friendly.
6.) apply fin to roof with pressure for 30 seconds...and the rest is history.
7.) Will report back if any issues, but things look great, there's no gaps in 3m tape (i would assume this is important even though the housing is protected with a rubber washer and is encased in plastic).
Hope this helps someone out, enjoy.
Also, if you want the internal wiring portion with connection ports I have an extra. Not sure if this is useful for retrofits, but thought I'd throw it out there.
      03-10-2013, 08:31 PM   #2
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
whatcha drinking there?
      03-10-2013, 10:01 PM   #3
mikefromMA
Drives: 2017 m4
2017 BMW m4  [0.00]
2015 428  [0.00]
hahaha I was waiting for it. it's coke....and jack daniels
      03-11-2013, 01:08 PM   #4
Lorde
Ya ya ya, I am Lorde, ya ya!
Lorde's Avatar
Drives: E90 M3, 2015 SQ5
2008 BMW M3 E90  [0.00]
Thanks for the write up! I have a bunch of random scratches on my fin and am looking to replace it with a new one from IND (significantly less than getting one from BMW, by about half). Figured that piece would be the last thing to scratch on the car!
      03-11-2013, 01:32 PM   #5
j2m
j2m's Avatar
Drives: '11 E92 M3 DCT
2011 BMW E92 M3  [10.00]
Perfect DIY instructions!
I've done this a few times exactly as described and worked perfectly
p.s. nice watch
11' E92 M3 Space Grey | DCT | ESS VT2- 625 | Gintani Race (valved) + Quad Res Catless X-Pipe | KW Sleeve's | GC Camber Plates|Arkym Diffuser | Vorsteiner VRS Lip | P3 Boost Guage | Stud Conversion
PHOTO's: Click Here ESS VT2 625 PHOTOS: Click Here
      03-11-2013, 01:51 PM   #6
Johndong888
John
Johndong888's Avatar
Drives: '12 M3, '18 S560, '16 G63
It's pretty much just held up by 3m tape. This DIY is exactly how I did it however a word of advice if I may, where you cut the tape, I would put another piece of 3m tape behind the gap to prevent or at least reduce the amount of water that gets in when it rains and what not.
Current - 2012 AW/FR E92 M3 | 2014 AW X5 | 2015 MB S550 | 2016 RR V8 (White FTW)
Mods - BPMTune Stg1/Servo, Euro Visors & Side Mirror, IND Gloss Blk Pkg, OEM Perf. CF Trim/Spoiler, Grills, Lights, Pedals, Umnitza V4 AE, ModeCarbon GTS V1, 19" HRE P40
Sold - 2008 BSM/Black E92 335i
      03-11-2013, 02:25 PM   #7
mikefromMA
Drives: 2017 m4
2017 BMW m4  [0.00]
2015 428  [0.00]
Thank you. The picture doesn't do the coverage justice. Some of the red tape was removed in cutting though the actual tape was consistent all the way around. Nevertheless, great point.
      03-11-2013, 02:27 PM   #8
mikefromMA
Drives: 2017 m4
2017 BMW m4  [0.00]
2015 428  [0.00]
p.s. nice watch
Thank you, next to the BMWs, that's my other "sickness" ha
      05-23-2016, 10:22 AM   #9
6cylinder
6cylinder's Avatar
Drives: E92
I used the 3M VHB 5952F tape and it is amazing. It is 1.1mm thick and has the perfect thickness to fill the small edge around the fin to mount it on the roof perfectly again as it was before removal
      06-05-2018, 06:28 PM   #10
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
so it doesn't matter sedan or coupe
M or non-M
all the same?
thanks for the info
i want to wrap the roof of my white e90 m3
shop said they won't wrap the fin and it's easier to just replace it
so i want to make sure i'm looking for the right part
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22
      07-05-2018, 10:29 PM   #11
mikefromMA
Drives: 2017 m4
2017 BMW m4  [0.00]
2015 428  [0.00]
M or non-M
all the same?
thanks for the info
M or non-M
all the same?
thanks for the info
That is correct
m3post
