M5POST
Go Back   M5POST - BMW M5 Forum > M5 Classifieds > Sponsors Classifieds
      03-07-2013, 04:44 PM   #1
Nate@IND
Nate@IND's Avatar
2865
RKP F10 M5 front lip (now available)
To this date, composites manufacturer RKP has specialized in obtaining the unobtainable- exterior components from the BMW M3 GTS, ensured by BMW to be impossible to purchase directly were faithfully reproduced in the highest level of quality.
Now, RKP takes the next step forward in their evolution as a composites manufacturer.
The RKP front lip for the F10 M5 attempts to go above and beyond the standard fare of aerodynamic parts available for BMW M cars. Where most front lips simply extend and lower the front of the car, the RKP lip adapts the original BMW design, and attempts to expand on what’s already there.
Instead of simply jutting straight from the front bumper, the RKP F10 M5 front lip is designed with BMW’s own design language in mind, integrating the crisp lines of the front bumper into the lip’s surface. The body lines molded into the front bumper of the M5 are retained in the outside surfaces of the front lip, and move and flow into the front lip’s outer surface to create a piece that is visually cohesive.
This F10 M5 front lip fits perfectly against the M5’s front bumper, leaving essentially no gap after the lip is installed. Installation is accomplished using 3M adhesive tape, and fasteners that are already present in the front bumper. No drilling is required to install the front lip, and no new hardware is used. The RKP front lip does not lower the M5’s ride height as it does not extend past the lowest point of the front bumper.
Each RKP front lip for the F10 M5 is built from 100% carbon fiber, and is available in plain or twill weave. Extreme care is taken to ensure that each lip has an excellent weave pattern and alignment, with no misweave or flaws.
RKP F10 M5 front lip 1x1 or 2x2 weave = $1295.00
Item can be found on the IND website:
https://ind-distribution.com/product?sku=RKP-F10-M5FL
To complete an order please give us a call at 866.963.4520 or you can send payment direct to paypal id info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      03-08-2013, 11:57 AM   #2
Nate@IND
Nate@IND's Avatar
2865
Link to the lip on the iND site-
http://parts.ind-distribution.com/pr..._Lip%5E896.php
      03-11-2013, 03:10 PM   #3
M-bitious
M-bitious's Avatar
Netherlands
83
Drives: BMW M2
Looks like it is an oem option. Well done.
I was wondering if closing the gaps in the oem bumper had any negative influence on airflow or cooling. And can it take 200mph driving?
Thanks.
      03-11-2013, 05:24 PM   #4
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9571
Drives: G82 M4 / G87 M2
Thanks.
The coolers on the F10 will continue to function without issue- the E9x M3 has a very similar cooling and ducting arrangement, and accepted front lips without issue, with even BMW Motorsport themselves offering front lips for the car.
The RKP front lip is an incredibly snug fit against the OE M5 front bumper, and would almost stay in place without 3M adhesive tape. A very strong installation is ensured by using adhesion promoter prior to applying the tape (to a clean surface), 3M adhesive tape, and the original BMW fasteners found on the bottom of the front bumper. I have complete confidence that the front lip would not detach from the front bumper well into the triple digits.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      07-31-2013, 03:54 AM   #5
absix
Mu mu muh muli, maikouuu!
absix's Avatar
86
Drives: F10 M5; F25 2.0d;
Just put it on my car. This is probably the best fitment on an aftermarket part I ever experienced (and I've seen a lot). The installers were amazed by the quality and craftsmanship (and they have seen a lot). Thanks IND!
      08-28-2013, 11:51 AM   #6
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
1x1 plain weave RKP lips in stock and ready to ship
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      10-01-2013, 04:55 PM   #7
Nate@IND
Nate@IND's Avatar
2865
RKP 1x1 and 2x2 front lips in stock now.
http://ind-distribution.com/ind/bran...port-front-lip
      10-07-2013, 07:44 PM   #8
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
I may need another 2 by 2 lip. Just screwed mine up! Ugh...PM price to SD.
Ditto. I screwed up mine on street debris. PM me a price.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
      10-08-2013, 11:16 AM   #9
Nate@IND
Nate@IND's Avatar
2865
PM's sent over.
      11-20-2013, 12:56 PM   #10
Nate@IND
Nate@IND's Avatar
2865
All carbon weaves now in stock.
      11-20-2013, 09:15 PM   #11
cassidysdad
Drives: 2014 M5 gone, 2016 pms m5
nate
three questions
is the 2x2 weave stronger? or is the choice a personal one?
how durable is the cf to debris?
is DIY doable, i live in so cal (los angeles) is there a shop close if not
thanks
john
      11-20-2013, 09:17 PM   #12
cassidysdad
i forgot one more thing..
is there a picture of the color you mention on the lip?
since it comes in all colors, would like to see a good pic
thanks
      11-21-2013, 08:23 AM   #13
Nate@IND
Nate@IND's Avatar
2865
Originally Posted by cassidysdad View Post
nate
three questions
thanks
john
thanks
Tons of photos in this thread (painted, CRT stripe and molded)
http://f10.m5post.com/forums/showthread.php?t=812810
The 2x2 is not any stronger than the 1x1 weave. It comes down to personal preference. Also if you are going to be adding any OEM BMW performance parts then I recommend going with the 2x2 weave so that the lip matches all of the other carbon parts.
The lip is very easy to install and takes around 10 mins total. It comes with everything required for install and there is no need for any drilling or glue. For install we recommend EAS http://www.europeanautosource.com/ or Autotalent http://www.autotalent.com/
Please let me know if you need anything else.
      06-19-2014, 03:38 PM   #14
DentalBoy
DentalBoy's Avatar
50
Drives: 2016 M6 Gran Coupe
Originally Posted by Nate@IND View Post
Black Friday Special on all RKP parts!
http://ind-distribution.com/ind/brands/rkp
Is there a black friday special this weeK? Havent researched different lip/spoilers yet but this loks great.. What is the best possible price on this? Thanks, Jim
2013 M5
_____________________________________________
2016 M6 GC under construction,2013 F10 M5 Akrapovic(sold)
2012 F10 AW 550i MSPORT,Vossen CV3s,ACS Springs,Meisterschaft GTC,.Totalled!
E60 M5 Dinan stg3,hiflow throttle bodies,coldair,evosport rear diff,Eisenmann Race sold
E39 M5 UUC short shift,UUC Corsa and More Sold
      06-19-2014, 04:23 PM   #15
Nate@IND
Nate@IND's Avatar
2865
2013 M5
Hello Jim,
The promo code is no longer valid but I will have an RKP dealer contact you right away. For more installed shots please have a look at the this link-
      07-30-2014, 05:32 PM   #16
Nate@IND
Nate@IND's Avatar
2865
RKP 1x1 and 2x2 front lips in stock and ready to ship
      08-14-2014, 11:35 PM   #17
cassidysdad
sg painted spoiler 2014 zcp
pics of my car at the car wash
painted sg side grills
rkp sg front spoiler
      09-04-2014, 02:17 PM   #18
Nate@IND
Nate@IND's Avatar
2865
Thanks for the photo!
RKP carbon front lips in stock and ready to ship now
      09-10-2014, 01:49 PM   #19
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
RKP F10 M5 front lip spoiler is in stock and ready to ship. This front lip is designed with fitment and finish as the top priority. The RKP F10 M5 product line supports U.S. jobs by conducting both the design and manufacturing process in Milwaukee, Wisconsin.
Do not settle for sub par fitment and construction! The RKP F10 M5 front lip spoiler is manufactured of full carbon fiber and utilizes a UV protected clear coat. The end result is no yellowing or delaminating that is typically seen on overseas carbon replica parts. Each RKP lip spoiler comes pre-drilled with double-sided tape adhered and ready for install.
      12-31-2014, 12:12 PM   #20
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Clean, aggressive, and installs in minutes. The RKP F10 M5 front lip.
Available in 1x1 and 2x2 (BMW Performance) weave.
      01-07-2015, 12:13 PM   #21
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
RKP front lip on Monte Carlo Blue.
Photo credit: fotosbyalex.com
      03-05-2015, 01:00 PM   #22
Nate@IND
Nate@IND's Avatar
2865
RKP F10 M5 front lips in stock 1x1 and 2x2.
m5post
