F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Questions about E85
Studio RSR
      03-01-2013, 12:35 PM   #1
metrathon
Drives: 2012 328i Sport Line
Questions about E85
I got very enthused about JB4 stage 2 on E85 and I seriously consider using this alternative fuel. However, I have a list of questions:
Does it hurt the engine?
Will it void the warranty?
How bad does the mpg get?
If it is heavily subsidized, why is it still over $4?
On a stock 328i, will you gain anything or lose?
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara
      03-01-2013, 12:49 PM   #2
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
You should not run E85 on a stock car without an tune for E85.
It should not hurt anything, the N54 and N55 have successfully been running E85 tunes as well.
MPG, it's a guess, I would say a 20% drop is a good guess.
Warranty, just like the tune itself, if a component fails unrelated, like a blown strut-they would not be able to prove it. But if something fails, like a fuel injector, they may try and blame the tune and E85.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      03-03-2013, 04:46 PM   #3
slmdgee
Usofstance
Drives: 328I 6SPD
thats why always gotta mix it if you run e85 its like running race gas....
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      03-03-2013, 08:10 PM   #4
M3takesNYC
Drives: m3
You can easily run e85 mixed with regular pump. Something in the 25-35 percent e85 would work fine.
Grab a BT tool and monitor your fuel trims to make sure your fuel pump is not strained but other than that you get great power and a bit lower gas mileage.
You don't need a specific e85 tune. Even stock you will make good power as you will be able to hit full boost and timing targets with e85s cooling effects and higher octane. With a regular tune of any kind you again can run higher boost and timing. Its cooling effects alone are valuable and why its even better than race gas.
      03-03-2013, 08:25 PM   #5
Jamesons Viggen
I don't see a point in running a fuel with my car not setup to take full advantage of it.
Running e85 in a car with a specific state of tune to burn it properly and make full power from it, yep worth the effort. Mixing the fuel and making incremental power with the standard tuning, too much effort. So if I get a 25whp bump with an e85 tune on e85, mixing it and running a stock tune for say 7whp...worth it?
      03-04-2013, 02:12 PM   #6
reedo302
Estorilblau Member
reedo302's Avatar
Drives: Dinan Estoril 328i M Sport
In modern engines designed to run it, no. If your engine was not designed to run it, it can depending on what the seals and gaskets are made out of. Ethanol is corrosive to certain materials. Most modern vehicles can withstand this corrosion without issue. Older vehicles can't. Also, cars designed to run ethanol must have injectors capable of increased fuel delivery.
Generally speaking, E85 won't void warranties, but I don't know what BMW's specific stance is.
MPG varies by vehicle, but E85 requires 40-45% more fuel to match the power output by gasoline. However, it's important to note that ethanol has a higher ignition point, making it less prone to knocking and making it more agreeable with forced induction. If you are getting your emissions checked, ethanol is a good fuel mixture to run because your emission output will be lower than with normal gas.
E85 prices are subjective to region. Here in Minnesota, as well as in places like Iowa and South Dakota, E85 is less expensive since a lot of ethanol is produced locally. The farther ethanol has to travel, the more expensive it is. Ethanol can't be transported by conventional pipelines like gasoline and petroleum, as the ethanol will eat the seals and can cause leaks and rupture. As a result, it can only be transported by rail car or tractor/trailer containers designed to carry it. Ethanol requires a LOT of electricity, as well as a lot of water to produce it. This is a cost that gets added in, and is affected by electricity prices. Since E85 is inherently inefficient and a poor fuel choice, not a lot of people use it. Since the demand is not high enough, the cost is higher to offset the costs. E85 is actually even more expensive, but it's being subsidized federally. Not only that, but the money coming from the E85 has to help with funding to keep things rolling so that the subsidies can also be doled out to the farmers who are producing the corn.
I originally grew up in farm country and have cousins that still grow corn and sell it for ethanol. None of them use ethanol, and I know farmers across Minnesota and South Dakota, and none of them use E85 either. Almost all of them sell their corn, despite several having cattle. They make more money by selling the corn and growing additional crops of things like sorghum, hay and turnips than just straight feeding corn to the cows. Corn prices are so high that many farmers aren't feeding it to cows anymore because it's not cost effective. E85 is essentially a farm subsidy.
Biodiesel from vegetable oils or from blue algae is actually a very legit fuel source with a future. E85 will hopefully die.
      03-05-2013, 12:22 AM   #7
M3takesNYC
Drives: m3
You don't need a e85 specific tune. Any tune that runs higher boost or timing will run better and consistently more aggressive with e85 which is like racegas plus. I see you have a 328 so you wouldn't know about the 335 guys experience with this.
      03-05-2013, 09:08 AM   #8
Jamesons Viggen
I thought you were saying mixing e85 on a STOCK tune.
You said, "You don't need a specific e85 tune. Even stock you will make good power..."
Now you have changed your wording to say that a non E85 specific tune, but a tune none the less with higher boost or timing.
Two different scenarios.
It has nothing to do with me having a 328 vs a 335(a couple friends run JB on N54's), I am just replying to what you write at the time.
      03-05-2013, 10:40 AM   #9
metrathon
Yes it has, yes it has: yours is smaller
So just to make sure I understood: if there is NO TUNE (so just stock) there won't be any (real world) difference, but you can still safely use E85.
      03-05-2013, 10:47 AM   #10
Jamesons Viggen
No, even if it's bone stock, I could see a SMALL gain from E85, especially on a hot day where knock is more likely. But we are talking about a few hp, and to me it's not worth the effort to seek out E85 over that.
Now, these E85 BMS tunes which can show a 10-20-30whp gain over the same car on 93 octane, why the hell not?
      03-05-2013, 11:37 AM   #11
chugster
B0$$
chugster's Avatar
Drives: 2020 HS M2C
besides a tune, don't u also need a new fuel pump to even handling the e85?
I know a lot of people with n54 had to upgrade that to do the e85 mixture tune.
Prev:
2013 AW/Coral Red 328i Sportline- Mperf. Black Grills, Mperf. exhaust, Prem. pkg, Tech pkg, Lighting pkg, Heated seats, Sports 8spd w/paddles
2016 CWP STi FBO E85
      03-06-2013, 08:33 AM   #12
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
In the Evo world you needed to change the fuel pump, fuel lines and fuel rail to handle how corrosive e85 is. Since nobody has run e85 in a f30 for prolonged periods (presumably) I don't think we can say whether it is harmful for the car. One variable we don't know is how flexible the BMW ecu is - can is recognize the mixture of regular fuel/e85 and adjust on the fly?
As for warranty I think the likely scenario is this - you take the car in for a problem with how it is running. After searching for and not finding obvious fault codes or defects, BMW directs the tech to take a sample of the fuel and test it. If there is a way for BMW to blame the running condition on the fuel, they will. Whether that voids the warranty, or simply leads to a denial of a warranty claim for that individual fault, it is tough to predict.
I ran into this issue with my parents' e92 335i - it was going into limp mode regularly and BMW tested their gasoline (I watched them do it) and blamed the limp mode on their use of low quality gas. The only way BMW eventually replaced HPFP's and injectors was after the car went in for service with good gas in the tank and it was still having issues (this was very early in the hpfp debacle). It is not tough to see the same happening with e85.
All I can say is I really hope our cars have sufficiently robust fuel systems, flexible ecu's and can run e85 with no mods!!!!! I want it!
      03-06-2013, 01:33 PM   #13
1bad335
Drives: 2007 335I/ 2012 335I sportline
IMHO, it is not worth it. Here in NY the savings on E85 as opposed to straight gasoline is almost a non factor. If I were to run E85, I would have bought a vehicle set up to run that fuel. BMW has not set up their vehicles to run E85 and I am sure they would void your warranty in a heartbeat if they find that you are running E85 in your vehicle. I think it would be pretty easy to void most mechanical failures other than suspension if E85 is found in your BMW. I did in fact have a Tahoe that ran E85 and the MPG was absolutely horrible and the loss of power was very noticeable as well. In the end it's up to each owner to make the call on what they want to do.
      03-07-2013, 01:50 AM   #14
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
Never mix e85 its a waste!!
      03-07-2013, 04:35 AM   #15
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
The info on the inside of my fuel filler cap states not more than 10% Ethanol, amongst other fuel recommendations.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      03-07-2013, 11:21 AM   #16
tdizzle
Drives: 2017 F80 ZCP
Depends on your definition of 'waste'. Go check out the numbers JB4's put out on 93 vs a mix of E85. Some huge gains are seen, especially out of the 335's.
      03-08-2013, 02:05 PM   #17
pkimM3r
pkimM3r's Avatar
205
think about what it could do 100% e85 lol.
      06-12-2020, 07:03 PM   #18
Justin_F32
Justin_F32's Avatar
22
Drives: BMW 435i
I have a 435i with Bm3 e30 tune i just filled up with 5.6 gallons of e85 and 16.6 gallons of 93 did I put too much e85? So far the car didn't seem to be missing
      06-12-2020, 07:08 PM   #19
sqwinny
Drives: 2013 6MT 328i M Sport
Way to bring up a 7 year old thread.
Also. How are you putting 21 gallons of gas into an F3$ ?
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
      06-12-2020, 11:39 PM   #20
DadzBmer_N2o
DadzBmer_N2o's Avatar
Drives: F30 320ix
I thought all models are 15.9 gallons full?
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o
      06-14-2020, 12:01 AM   #21
sqwinny
That's my point. how do you have a 20-gallon tank...
      06-14-2020, 10:12 AM   #22
Justin_F32
Justin_F32's Avatar
22
Drives: BMW 435i
My bad I think I looked a how much I paid Instead if gallons
f30post
