02-27-2013, 03:48 AM | #1 |
Rep 166
Start Stop Query & Turbo cooling.
I see the start stop doesnt work when the engine is cool & starts to operate after reaching a minimum engine heat level.
But what after a high revving run if i approach the traffic light (or on a track) & the engine shuts down to save fuel wouldn't it harm the turbo ? Ideally turbo engine would require an idle time of 30-60 secs to cool off the TURBO (Practice for longer Turbo life) Does the engine shut down ? Or is there a higher limit temperature specified ? after which the start-stop disables itself. What are your observations on the start stop tech after a high revving run ?
BMW F30 328i (A/T) | Toyota Fortuner 4x4 (M/T) | Toyota Hyryder Hybrid (e-CVT) | BMW G20 M340i | Skoda Kushaq (A/T) | Kia Seltos (DCT) | BMW E46 328i (M/T)
02-27-2013, 10:49 AM | #2 |
Rep 88
Start-stop will not trigger even if one of the dozen parameters are not met. I am sure that ASS also checks for engine/turbo temp and if it's too hot for it to shut down it wouldn't kick in.
Also modern turbos don't need "idle off" to cool. Correction, I should say modern turbo designs don't need cool off. Even if the car is shut off after boosting into your parking spot, fan will remain on in order to cool it down to a safe level before everything shuts off. So by the same standard, it is safe to deduce that even under engine off with ASS the fan will continue to cool it down at stoplights. |
02-27-2013, 11:07 AM | #3 | |
Rep 549
OP, let the car shut off, you don't need to worry about it. |
02-27-2013, 12:06 PM | #4 | |
Rep 88
Just wondering what keeps the oil/water circulating. Is it the pressure or is there an active pump? Thanks. |
02-27-2013, 12:28 PM | #5 |
Rep 549
On most cars, its basically a gravity feed like I said. It works like a siphon, the way the oil/water flows, the hot water gets forced though and keeps pulling cooler fluid behind it till it reaches a certain temp.
02-27-2013, 12:32 PM | #6 |
Delivered!
13
Rep 139
In addition, the coolant pump is electric, so it is possible that the ecu will continue to pump coolant through the engine/turbo/etc. while the vehicle is off/standby if it detects that there is a need. I do not know that it does this, but merely highlighting the possibility.
Also, apparently the oil pump is electric too, so same logic applies here as well.
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
02-27-2013, 01:33 PM | #7 |
Rep 166
N20 has a water cooled turbo right ?
02-27-2013, 01:37 PM | #8 |
Delivered!
13
Rep 139
This entire topic has been discussed HERE. Summary: N20 turbocharger is oil and water cooled, and so is the N55.
02-27-2013, 04:38 PM | #9 |
Rep 342
Drives: 2019 BMW M760li
After a hard run, shut the engine off and pop the hood. You'll here the gurgling of fluids flowing through the turbo and the faint hum of an electric pump. You may also note a glowing red color from the turbo housing
Either way drive hard and don't worry about it. She'll take care of herself. If you have any doubt, before you park take a slow cruise around the block. |
03-07-2013, 12:23 AM | #10 | |
Rep 1
