E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > JB4-Misfire on Map 2 only?!?
      02-09-2013, 09:20 PM   #1
LAZ
OneThirty5Eye
LAZ's Avatar
Drives: 135i, 335i
1- I have been running JB4 for a couple of months now. I have been running Map 1 with DCI and 93 octane...The car runs great under map 1. I recently installed BMS downpipes. However, when I switch to Map 2 I often get a misfire code for Cylinder 2. I have done pull after pull to see if the JB4 simply has to "learn" but after many pulls the problem remains. Map 2 runs ok when I WOT from a higher speed (60 roll) but misfires when I WOT at lower speeds/gears (20-30mph). Can running this extra 1.5 psi cause the car to go from having ZERO misfires on map1 to misfires almost EVERY time with map 2? Or do you think there is another culprit causing this issue?
Also
2- Based on your experience...I have an Automatic Transmission...my car's oil temp easily hits 250 degrees but doesnt really go past that after some spirited driving. A day after installing my BMS downpipes I noticed that my car seemed to be hesitant to shift from 3rd to 4th at WOT...its almost seems like it stalls before the shift...and on occastion the exhaust would sound like its makes a fart noise between shifts, as if its having a hard time breathing. I have no experience with aftermarket downpipes. Does this seem normal? Do you think the 250 degrees can cause the transmission to not preform to its full potential?
Any help from those with Jb4/DP experience would be greatly appreciated.
Thanks
      02-10-2013, 01:30 AM   #2
Hybrid For Life
Germany
79
Drives: Out of Spec
Post this in the n54 section, you'll be better help over there
      02-10-2013, 07:20 AM   #3
andrew335i
Drives: 2009 335i e92
Also
Thanks
Data log a pull with the misfire happening and send you log to Terry. He can tell you what's happening
      02-10-2013, 05:22 PM   #4
AWil335i
AWil335i's Avatar
12
Drives: 2007 E92 335i
Higher boost = higher strain - it's probably spark plugs, a coil, or injector. Start by swapping the plug with another cylinder and see if the misfire moves. If not, repeat for the coil, and finally the injector. When it moves, you've found the problem.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS DPs | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Tags
downpipe, jb4, map 2, misfire, misfiring
e90post
