E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > headlight on the driver side not moving
      01-31-2013, 02:21 PM   #1
thung_mail
Drives: 2007 e93
Post headlight on the driver side not moving
Hi all
I have just noticed that my headlight on the driver side is not moving but the passenger side does when I make a left turn or the right turn. Is it normal or my headlight motor on the driver side has a problem...How is about your drive....
      01-31-2013, 04:23 PM   #2
koss2010
Drives: 09 335i coupe
Shouldn't that trigger some sort of malfunction code ?
      01-31-2013, 08:41 PM   #3
BKV122
BKV122's Avatar
Drives: E90
2006 330xi  [9.50]
It would if the actually motor that controls the headlights is NG.
I had a problem where the motor arm popped out of the socket on the headlight. SO the motor was still working fine it just wasn't attached to the headlight.
Check this out, might be your problem...
http://www.e90post.com/forums/showthread.php?t=494479
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
      01-31-2013, 09:02 PM   #4
thung_mail
Drives: 2007 e93
thanks all,i'll be check it out later.
      01-31-2013, 09:20 PM   #5
Wolf 335
Wolf 335's Avatar
Drives: 2007 E92 335i
i have a problem with my driver side, however mine turns right and back to center but will not go to the left.
      01-31-2013, 10:17 PM   #6
E90_boostjunky
E90_boostjunky's Avatar
93
Drives: BMW 335I E90 SGM
It's normal, I thought I had the same problem, but it's for safety when you are at a stop light for the oncoming drivers, it works perfectly fine when your moving. Unless your having some other serious problem.
      02-02-2013, 02:16 AM   #7
thung_mail
Drives: 2007 e93
@wolf 335 and e90_bootsjunky: you are right, when you are driving, steering left or right will tilt the headlight as well. However, when I am in parking mode, headlight ONLY works when turning the wheel to right and back. Is it about the safety or else ......
Does the headlight work in the opposite way with right hand driving ( UK and colony of UK ) ???
      02-02-2013, 01:44 PM   #8
speedco
Drives: 07 E90
I could be wrong, but I've been under the impression that US model BMWs that are equipped with Adaptive Headlights make sure the DRIVER'S side headlight will not turn to the left if the car is turned to the left.
The reasoning behind it, I believe, is because if you are on the shoulder of the road, and you pull back into traffic, the driver's side headlight stays centered so you don't blind oncoming traffic.
e90post
