ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Track / Autocross / Dragstrip / Driving Techniques
  TireRack
      01-18-2013, 10:39 AM   #1
davesz4mc
Drives: 2007 z4mc
Drag Times Thread
We should start a sticky so people can see the basic changes certain mods might cause as people post and update thier faster times. I do not consider this a drag car by any means, however there is nothing wrong with a little fun at the track instead of on the street.
My fastest time so far will post he slip when I have more time.
This is with the below supporting mods.
Trap Speed = 109.20
1/4 Mile = 13.31
60' = 2.20 = horrible
This is with a roll off start no dropping the clutch or anything. With drag racing it is all about trap speed, it should stay the same even if your 1/4 mile time flucuates. So with a perfect launch "not gonna happen" the car now should be in the high 12's.
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
      01-18-2013, 01:02 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
My weight is 3187lbs, putting down around 400-410rwhp on 8psi
Ambient temp was around 75*F, slip on the right
      01-18-2013, 04:34 PM   #3
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
Here's the data off my best (but still slow) time slip when I took my 3.0 si out with some friends.
R/T .535
60' 2.329
330 6.382
1/8 9.718
MPH 75.45
1000 12.540
1/4 14.922
MPH 94.36
If I recall correctly, bases on my assumed weight at the time, the quarter mile speed turned into something not to terribly bad for powertrain loss from a stock 255 hp motor.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
zpost
