XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Vendors Classifieds
      01-17-2013, 02:10 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
812
Drives: Independent Tuning Specialists
:: ECS Tuning :: N54/N55 Deep Well Spark Plug Socket|Schwaben Tools
Many service procedures are easy with the right tool--and darned near impossible, without it.
Case in point: The Schwaben thin-walled deep-well spark plug socket is designed with the BMW N54/N55 3.0L in mind. The narrow plug tube in the 3.0L engine is not wide enough to accept common plug sockets, which can stick in place. Really stick.
The Schwaben thin-wall design fits easily in the plug hole. Its magnetic ring holds the plug safely during installation, then lets go when it should for fast socket retrieval.
If time is money, this socket pays for itself on the first job.
Click HERE to order today!!!
      02-19-2013, 03:59 PM   #2
ECSTuning
ECSTuning's Avatar
812
How long as it been since you serviced your ignition? If your BMW's mileage is getting up there, be sure to keep your ignition system in check. Whether you currently have a misfire or you're just doing preventative maintenance, these kits are for you. Pair our Service Kits with the Schwaben Deep Well Spark Plug Socket and your ignition service will be done in no time!
Click HERE for your N54 Ignition Service Kits
      07-25-2013, 09:54 AM   #3
ECSTuning
ECSTuning's Avatar
812
xbimmers
