BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      01-14-2013, 11:48 PM   #1
kaiv
IG: limited.slip
Drives: E46 M3 in a 325i Touring body!
AIM SOLO DL install / PNP wiring DIY
If your unit came without instructions or without pictures, well there you go
The SOLO DL connects to the CANbus of the car. Just two wires. + and -. It's pretty easy stuff but I cannot be held responsible if you screw up your car. I suggest reading this entirely before proceeding, so that you understand what you're doing </disclaimer>
I originally found said two wires on the big DME connector in the engine compartment. Then after some google-ing realized there is a big subconnector below the glove box. Perfect!
1) Disconnect the battery's negative terminal (8mm)
2) Remove the panel underneath the glove box (two T20 and 1 connector)
3) Find blue connector
Unplug it by pressing on the tab in the middle and lifting the white latch
4) Pull out the subconnectors by pressing on the tabs on either side
5) Locate PIN 1 and PIN 2.
PIN 1 is a blue wire with a red strip (CAN+) and PIN 2 a solid red wire (CAN-)
(You will need to remove some factory cloth wrap to see the wires)
6) With a pick tool press on the metal tab of the wire to slide it out of the connector. Undo both wires
7) Connect the PNP harness' red wire in PIN 1 and the blue wire in PIN 2. You do that by just sliding it into the connector all the way until it clicks.
Yes, logic and common sense would want you to connect the red wire where the red wire was and the blue wire where the blue wire was but it's not the case... I tried. Don't mind my chipped connector and my repaired wire -_-
8) Now connect the wires you removed to the supplied (green) connector. Blue to PIN 1. Red to PIN 2. and plug it to the female green connector on the PNP harness.
Red goes to blue, blue goes to red? What?! Logic fails again
9) Time to test your install.
Slide the subconnectors back into the blue connector.
Plug and latch the blue connector.
Reconnect the battery.
Connect the AIM SOLO.
Start the car (FYI if the CANbus is improperly connected it will take longer to start, the dash will be a Christmas Tree and things will be acting up severely ).
Start the SOLO
Everything checks out...Success!
10) Clean up your install. Unplug the SOLO and route its wire however you want it (I routed mine from behind the glovebox)
11) Tug in and secure the wires and harness (zip ties)
12) Reinstall the plastic panel (tabs on either side + light connector+ 2 screws)
13) Enjoy your SOLO!
Visceral363.00
      01-15-2013, 06:43 AM   #2
S65V8
*_*
Drives: ...
nice job! With a little research and tinkering, it's amazing what any of us can do on our own. I started doing this myself for a number items as labor these days so expensive everywhere.
      01-15-2013, 12:07 PM   #3
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
Thanks for posting this up!
      01-15-2013, 12:40 PM   #4
OC3
Havin' a blast!
OC3's Avatar
Drives: 2013 M3 E92 Jerez Blk DCT ZCP
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
      01-15-2013, 01:34 PM   #5
bigjae1976
bigjae1976's Avatar
1570
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Nice work! But you fail as a hand model. You should have gotten a manicure before doing the DIY.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      01-18-2013, 10:50 AM   #6
GTM_Challenge
:rofl:
      01-29-2013, 05:43 PM   #7
kaiv
IG: limited.slip
      06-12-2013, 06:24 PM   #8
Aus_M
Drives: BMW M3
Just used this guide, worked perfectly! thanks
      06-14-2013, 10:49 AM   #9
kaiv
IG: limited.slip
Awesome, glad it could help!
      09-23-2017, 12:45 PM   #10
ufgtrs2007
dentite
ufgtrs2007's Avatar
339
Drives: 718 GT4, M2C, JLU392, e92 M3
2013 BMW M3  [0.00]
2013 BMW M5  [0.00]
I'm reviving an old thread. Do I need to purchase the green connector? One did not come with the AIM. And there are several other wires in the harness, do I need to use all of them?
Thanks
      09-23-2017, 12:51 PM   #11
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
Thanks
Green connector is just a wire tap. Not necessary but clean. You will have unused wires
He is using the pnp kit from mworld it seems.
Exclusivs542.00
      11-06-2017, 07:42 AM   #12
peter de la mare
Drives: 2008 BMW M3
Only two wires are required, the CAN+ and CAN- ? The power/ground wires are redundant?
      11-06-2017, 07:45 AM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
They are, only if you want to use the unit on battery all the time.
You can wire the power/ground to a switched accessory fuse and the AiM will turn on with the car.
This is what I plan to do.
I also don't see the point of this PnP cable at $175!!!
This that just obscene pricing for what it is.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      11-06-2017, 04:52 PM   #14
peter de la mare
Drives: 2008 BMW M3
Thanks for confirming, I’ll find a suitable power source.
I’m currently suffering CANBUS errors with the AiM and Awron gauges conflicting, I’m picking up the CAN feeds from the same place under the glove box using a home madden loom using OE connectors and leads. Apparently a 1k resister will stop them from crossing over.
If this fails then I’ll wire directly to the ECU and hope this works.
      11-06-2017, 05:00 PM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Direct ECU connection also gives you more useful data.
      11-25-2017, 08:54 PM   #16
Exclusivs
Exclusivs's Avatar
Drives: E92 M3
Good write up kaiv This goes much appreciated
      09-18-2019, 12:02 PM   #17
semaj
Drives: 135i N54
2010 BMW 135i  [0.00]
Start the SOLO
Will this method give show channels available to the "BMW_PT6" protocol? You can see it listed here: https://www.aim-sportline.com/downlo...T6_101_eng.pdf
      09-18-2019, 12:45 PM   #18
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
Yes.
      08-30-2020, 05:49 PM   #19
swhat
Drives: '11 MW E92
Adding on to help those upgrading to Solo 2DL. Just follow the above instructions, but for power wiring, refer to this:
https://www.manualslib.com/manual/10...page=13#manual
Power wiring is on the black ecu connector pin 1 (15v wiring) and pin 6 (ground).
      08-30-2020, 08:23 PM   #20
derbo
Derbo Tuning
derbo's Avatar
3609
Drives: BMW M3
Thats interesting.
I used Fuse #5 (it was empty) and use a tap a fuse and the fusebolt mounting bolt as the ground.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
m3post
