E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Downpipe fitment issue (v-clamp won't close)
      01-12-2013, 09:43 PM   #1
blaze739
Drives: E92 2008 335i - AW/CR
2008 BMW 335i  [9.34]
So I finally got around to installing my downpipes but I am having a issue with the longer downpipe (front turbo). I can't get the v-clamp to close on the pipe/turbo flanges because the Downpipe flange doesn't sit flush against the turbo. On one side it is flush, but on the other side there is a small gap about halfway around the pipe. Even though the v-clamp grabs both, it does not close because the flanges are not tight enough.
Has anyone encountered this? Are there any suggestions or do I need to replace the downpipe because of a poor fit? I will try posting pictures tomorrow. Thanks in advance for the help.
      01-13-2013, 10:09 AM   #2
saxon
Drives: s4
could possibly deck the flange on the new downpipe for a better fit
      01-13-2013, 11:16 AM   #3
Red_Bean_Bun
Drives: E92
Heard that part is tough for some people here ...... which DP is this ?
      01-13-2013, 12:50 PM   #4
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
If the V band is out of round or warped it will likely never fit. Perhaps you want to contact the manufacturer and tell them.
      01-25-2013, 08:28 AM   #5
blaze739
turned out to be a defective pipe. i swapped it out for a different one and everything it great now. v-clamp is closed to about 1/4" with nothing touching. No noises or vibrations and im loving the new feel. i never realized the sound of the turbos would become so much more noticable. can't wait to test the additional power once it gets above 10 degrees in NY
      01-25-2013, 08:47 AM   #6
Eric335
Eric335's Avatar
Drives: 2007 E92 SG 335i 6MT
2007 BMW 335i  [7.66]
I had a similar issue, the clamp was slightly warped and was very close to starting to thread but wouldnt. After 3+ hours i ended up making sure it was completely on, then using pliers to close it. It worked perfectly and without much resistance. No exhaust leak after several hundred miles
      01-25-2013, 11:42 AM   #7
subbie79
Drives: 2007 335i Sedan
Did the same thing. Used pliers to close the gap, no exhaust leak so far (~10,000 miles)
      01-25-2013, 12:18 PM   #8
blaze739
any smells in the cabin at all? the awful new downpipe smell went away after 2 days, but i still get a burning smell when i park in the garage. i'm thinking it might need a few more days unless i have a leak. everything sounds good tho.
      01-25-2013, 12:20 PM   #9
Did you clean the pipes before you were done?
      01-25-2013, 03:01 PM   #10
E90Company
E90Company's Avatar
Drives: Car
What pipes were these for reference?
      01-25-2013, 08:35 PM   #11
blaze739
Nope. I wasn't looking for any extra steps to the install lol. That could be it
      01-25-2013, 08:44 PM   #12
Eric335
Eric335's Avatar
Uhm what????? We were supposed to?
      01-26-2013, 07:41 AM   #13
spool twice
Rainbow Racer
spool twice's Avatar
Drives: BMW M4cs
2019 M4cs  [0.00]
Small vice grips work too
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ]
Current Car: F82 M4cs | TT-RS | On Order: i4 M50
      01-26-2013, 11:10 AM   #14
Eric335
Eric335's Avatar
Very true. At that point of the install i was about to kick the damn car off the jack stands and sell it hahahah
      01-29-2013, 10:59 PM   #15
jspecvtec
Drives: s2000
Had same problem. Got new v clamps from dealer for $16 each and fit perfect. Old ones got warped
e90post
