F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it true that if I disable the seat belt gong it will also affect the airbag?
ARMA SPEED
      01-07-2013, 06:13 PM   #1
f302012sold
f302012sold's Avatar
Drives: F30
EDIT: a better (safer) way to make the seatbelt gong less annoying
Heard someone mentioned about this somewhere, if I do:
SBR_FA_GWF_SBR_FA -> 00 (not active)
SBR_BF_GWF_SBR_BF -> 00 (not active)
it does kill the seatbelt gong noise but it also kills the seatbelt warning sign too. If this affects the airbag in anyway we should advise people not to touch it. Any idea?
PS. I tried:
Gwf_SBR_Warndauer -> 5 but it didn't reduce the gong to 5 seconds. Does it have a minimum number of seconds?
EDIT:
To make the seatbelt warning gong less annoying, try shorten the length of the warning rather than disable it completely. Do:
Code:
Gwf_SBR_Warndauer -> 05
      01-08-2013, 01:08 AM   #2
ilhan1103
ilhan1103's Avatar
11
Drives: f30 318 2012
2012 318D  [0.00]
if you put 5 in Gwf_SBR_Warndauer, it will not set the timer to 5 seconds.
These are hex values, you can find a converter online easily.
but for reference :
64 hex (actual value you enter) = 100 (seconds in this case)
19 hex = 25 seconds
      01-08-2013, 04:18 AM   #3
f302012sold
Drives: F30
but for reference :
19 hex = 25 seconds
thanks ilhan1103 i knew hex but surely "5" in hex is 5 in dec. So i bet there must be a lower limit. did you try 19hex and it definitely worked?
      01-08-2013, 05:23 AM   #4
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
I don't speak hex fluently and I didn't check yours, sorry if that was correct
Now that you mention it, I did try 19hex, but cannot recall the results.
I'll try again and confirm the result
      01-13-2013, 12:05 PM   #5
f302012sold
Drives: F30
It can be confirmed that it doesn't have a lower limit. If you put "05" instead of "5" it will work.
And personally it is better to do it this way rather than disable the sound warning completely because I noticed that when the sound warning is disabled the red seatbelt indicator on the dash will get disabled too. Although there is no solid evidence that it is not related to the airbag or anything but until it is confirmed, I will not recommend anyone in this forum to temper these settings to achieve convenience by sacrificing safety in such a great extent.
kern4174446.50
      02-16-2017, 03:13 PM   #6
Brett530
Brett530's Avatar
208
Drives: '17 F30 340i
Yes, I know this is a dead thread, but I like this solution better than just shutting it off.
A value of 06 made the warning sound 3 times, which is hardly enough to get noticed.
A value of 0B produced 5 warning sounds, which for me is just about right.
Overall, a safer way to not be bothered by the seat belt reminder.
I should add (since OP did not) that this setting is in ACSM
      02-19-2017, 09:01 AM   #7
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
If you set to 00, then it is just one warning sound.
f30post
