01-01-2013, 10:48 PM | #1 |
Rep 49
how to reset the light after an oil change and other services?
hi, guys i want to change my oil but i dont know how to reset the car to say service oil in 7000 miles after a fresh oil change or whatever the proper mileage interval is. Is there a certain tool that i need to purchase that i can use to set the intervals in between the oil changes or brake pads or any other general service that needs to be done. how do i do this?
thanks guys |
01-24-2013, 02:40 PM | #3 |
Rep 536
http://www.e90post.com/forums/showthread.php?t=384430
Worked for me after getting the brakes changed. Oil should be the same way. Dealer will charge you $125 for it. |
05-10-2013, 12:19 PM | #5 |
Rep 396
09-29-2013, 03:11 PM | #6 |
Rep 1,089
Are the wear sensors staged? E.g. I know on newer model BMW'S they have a 2 stage wear sensor. If i-drive shows I have 4k miles on pads but no wear sensor light is on, must I replace the sensors? Thanks.
10-17-2013, 09:21 PM | #7 |
Rep 1,089
I did a brake change and didn't unplug any sensors and have the brake light on now after doing the service reset when I didn't before. Can I just clear the codes in the ECU and be fine? Thanks. I don't think I need to buy new sensors right?
Tags |
brake pad change, diy oil change, reset light, service |
