Intermittent Oil burning smell/Smoke with new turbos
12-29-2012, 03:33 PM | #1 |
Rep 196
I had my turbos replaced under warranty less than a year ago. I am no longer under warranty and have recently started noticing smoke and an oil smell when I come to a stop. This happens on rare occasions and does not necessarily happen when I am getting into boost as I have thought that may provoke it but it does not. I know it may be the turbo seals but are there any other possibilities? It never does it until it at least 120 degrees. When it does it it can let out alot of smoke but it only does it for a few seconds and then stops. I am xxxless but can differ between fuel and oil smell. I am just looking for any experience or ideas that anyone may have.
12-29-2012, 11:58 PM | #2 | |
DIYER
614
Rep 5,521
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
12-30-2012, 11:52 AM | #3 |
Rep 196
The smoke is a bluish white and clearly smells of oil. It comes from both exhaust banks equally. ANd yes it goes away when accelerating. I have had people ride behind me to see if it leaves a smoke trail. MY car does not leave a smoke trail which makes me think it is something other then turbos.
12-30-2012, 11:55 AM | #4 | |
DIYER
614
Rep 5,521
12-30-2012, 05:54 PM | #6 |
DIYER
614
Rep 5,521
Very doubtful, but I would get one, do a valve cover gasket replace and upgraded valve. How many miles on your car with these turbos? I had blown seals in my turbos, car would smoke if it sat....not while cruising. When I gave robbeck my cores there where really bad....worst he has seen lol!!
If yiu do a valve cover gasket I have a easy DIY.
12-31-2012, 11:05 AM | #7 |
Rep 196
Not even 10k miles. The thing that makes me think it is a pcv problem is that i get a small amount of oil that appears to come from my filler cap. I cant find where to get the upgraded pcv. It should be a pain to change.
12-31-2012, 11:34 AM | #8 | |
DIYER
614
Rep 5,521
get the upgraded valve from RobBeck
12-31-2012, 03:00 PM | #9 |
Rep 1,271
When I had something similar happen, they replaced the valve cover gasket and also said that an oil line going to a turbo was leaking and dripping onto my exhaust. I was under warranty so they did all the work.
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
12-31-2012, 03:13 PM | #10 |
Rep 3,736
Your turbos are still under warranty, BMW extended to 85000 miles I think. Take back to dealer for inspection maybe.
01-01-2013, 10:34 AM | #11 |
Rep 196
Upon further inspection there seems to be no symptoms of a leaky valve cover.(no oiil rinning down the side of the block or any in the spark plug wells). I am thinking of ordering this upgraded valve and giving it a shot. Will probably order a bms catch can as well.
04-14-2013, 01:50 AM | #12 |
Rep 27
Drives: 2007 BMW 335I
Hey there, just wondering if you solved the problem and what was it? Thanks in advance
04-14-2013, 09:08 AM | #13 | |
Rep 232
i think i will do the the valve cover and pvc first. put back engine support ,dps and give it a try...
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
04-14-2013, 11:39 AM | #14 | |
Rep 6,136
04-14-2013, 03:06 PM | #15 |
Rep 232
valve stem seals...is usually on cold start up...smokes for a few seconds no ?
04-14-2013, 07:24 PM | #16 |
Rep 6,136
My buddy thought his car's turbos were blown for a long time. Started smoking at like 70k miles. At 99k he checked the (original) turbos, no oil found in them. These turbos made a very loud siren sound. Apon further inspection the turbos were made out to be 100% in working order even with the siren, and they found the stem seals to have crapped out. He would get smoke on deccel no matter what oil temp fully catless. When he put the cats back on their was no smoke.
04-14-2013, 07:47 PM | #17 |
Rep 232
o man.... another thing on the list for the cloud of smoke on deccel to verify.. damn
1- turbo seal -- most possible 2- pcv valve -- rb upgrade but no cure for smoke 3- vent hose -- no cure 4- valve cover gasket -- dosen't seem to fix the problem 5- valve stem seal -- second most possible 6- piston ring engine damage -- worst case senario
04-14-2013, 08:07 PM | #18 | |
Rep 6,136
1 you can verify by pulling the DP's and checking for oil in your turbine housings. 2 and 3 I would just revert to completely stock OEM PCV components. When I removed my OCC I bought new OEM check valves to be sure. 4 and 5 are going to be a pain. 6 Do a compression/leakdown test to see if your cylinders are honding their compression. If a cylinder is down compared to the rest you may have a ring sealing issue. Smoke is coming out of both exhaust ports i'm assuming, because you don't have divorced piping like an E90, rather an X-pipe. This makes it hard to determine which bank your smoke is coming from. With a PCV and valve stem issue it will be from both tips. If it's a ring sealing issue or turbo related it will be from one side most likely, unless both bank's components are shot. Last edited by E90Company; 04-14-2013 at 08:13 PM.. |
