12-28-2012, 04:19 AM | #1 |
Rep 56
HP gains w/ different exhausts...
Okay, let me see if I have this correct.
With just an axle back (i.e. slip-on), most systems show only a negligible hp improvement (i.e. less than 8hp), right? Thus, it basically does not matter whether I select Meisterschaft or Eisenmann, 3D Design or anyone else? We're just talking sound improvements at this point and everything is in the range of about $4k? For a full system, there seem to be more solid gains (which makes sense). Important to me are the gains without a tune or otherwise voiding my warranty. Meisterschaft claims 30hp for their full system (90mm LXR pipe) and the setup costs about $6k. Eisenmann can be purchased with their center pipe and total price is about $7k. Not certain about the piping diameter or the hp gains. RPI claims theirs makes the most hp (have they published the number?). Their piping is 77mm and their price seems to be the lowest (close to $4k?). Akra costs about $8k for a full system, but they only got 10hp and 13ft lbs torque. So, if I want hp without a tune, it seems like the choices are Meisterschaft vs. RPI. On price, RPI seems like a winner if it can put up legit numbers. However, their 77mm tubing vs the 90mm tubing of the Meisterschaft seems like a significant difference. Can the RPI flow as well? How could it? Looking for thoughts and opinions here as to what people are experiencing now that these systems have been out and in cars for awhile now. Thanks in advance. |
12-28-2012, 06:57 AM | #2 |
Rep 5,109
I believe your questions will eventually be answered here:
http://f10.m5post.com/forums/showthread.php?t=775934 |
12-28-2012, 09:26 AM | #3 |
512
Rep 1,437
Cant go wrong with either. I had an RPI setup on my M3 and loved it. RPI makes some good quality products. I chose Meisterschaft for my M5 because they offered the remote valves which was important to me. I absolutely love this feature. Oh, and the 102mm tips dont suck either. Sound is similar for both systems and I would bet the power increase is similar as well.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
12-28-2012, 10:01 AM | #4 |
Curve Thrasher
623
Rep 3,773
I just installed my rpi exhaust and am going today to see if I can get on the dyno. I will let you guys know my findings on my post on my rpi install.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
12-28-2012, 10:11 AM | #5 | |
Rep 1,341
Drives: 2013 M5 SSII
Do you have before numbers?
12-28-2012, 10:11 AM | #6 |
512
Rep 1,437
Did you do a stock dyno? A dyno with the exhaust without anything to compare it to would be pointless, no? Cant compare to other cars results. All cars, dyno machines, test environments are unique.
12-28-2012, 05:37 PM | #7 |
Curve Thrasher
623
Rep 3,773
I didn't have a chance to get before/after tests done. I wanted to, but it didn't work out that way with my work schedule. Actually the best way to do it would be to get the base line, change out exhaust same day and them get the after run. I know that all our cars are different, but hopefully these results are good enough to show everyone until i get to the dyno on monday for another pull.
Country run |
12-31-2012, 04:26 PM | #9 |
Rep 56
bclk55, that is great to hear. Butt dyno may actually be more important to all of us because improved throttle response is what will make these cars more fun to drive during normal conditions. A dyno chart showing some top end gains is nice at the track.
It's looking like RPI could be the winner here. |
12-31-2012, 06:12 PM | #10 | |
Rep 198
01-05-2013, 05:14 PM | #11 |
Curve Thrasher
623
Rep 3,773
Looks like the butt dyno was on point with the real dyno. oh yea.
Country run |
01-10-2013, 12:05 AM | #12 |
Rep 168
Mmm
The best M5 exhaust is the Manhart Racing, we'v tried them all and got the most hp gain with manhart and G-power as they come from the same manufacturer and are exactly the same! The only difference is the print on the tips. To get the max gain install BMC filters, manhart catbacks, sport downpipe, and ecu tuning. By that ull get about 645+
