BMW M3 Forum (E90 E92)
BPM
      12-27-2012, 07:57 PM   #1
Dannys M3
Dannys M3's Avatar
Drives: Jaguar F Type R
2008 M3  [10.00]
windshield washer fluid leak
I did a search and found a few threads that mentioned this leak but no real resolutions other than the dealer replaced the tank. In order to access this area you have to remove the front passenger wheel. After you have placed the car on jack stands and removed the wheel, start removing the panels. You will need a 8mm and 10mm sockets along with a T30 torx bit. First remove the lower rear corner panel, then the front which has two screws hidden on the right side of the vent, and last the large rear section of the wheel well.
As you can see my leak is at the pump plastic housing where I put the red arrow. I did not replace the pump. The part number for the pump is 67128377430 and Tischer lists it for $72.84. However to stop the leak I cleaned the area with a degreaser and sealed it with Loctite ultra gel control super glue using three coats. We'll see how long this repair lasts. Maybe when I order my next oil change kit I'll include this pump as part of the order.
Last edited by Dannys M3; 02-01-2013 at 06:29 AM.. Reason: Correct part number and price
      12-29-2012, 11:07 AM   #2
TxStig
Drives: 2008 E92 M3 Jerez Black
I too have this leak. Thannks for the info!!
Biginboca3761.50
      01-02-2013, 11:10 AM   #3
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
You are welcome. I am not sure if excessive movement caused the crack or not. As you can see one of the wires is not in the clip. So far the temp fix has held, good luck with your fix and post pictures of your leak is somewhere else.
      01-11-2013, 08:45 AM   #4
pOKa
pOKa's Avatar
United Arab Emirates
Drives: 09 E92 M3
I too had the same problem. Puddle under right front wheel. Took it to dealer, they said to change pump. Part + labour approx. $200…
Had it fixed just few days ago. Hope it stays that way.
      01-11-2013, 01:07 PM   #5
happos2
Dingleberries
76
Drives: Gray E92 M3
I assume I have this leak, will look this weekend. I just filled the resivoir with 3.5 litres (max is 4.5 I think from the manual). I already have a low resivior warning and I used the washers once.
Thank you for the write up!!
      02-01-2013, 06:31 AM   #6
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
Temp repair only lasted 2 months. I will order a new pump with my next oil change kit.
      02-02-2013, 10:43 AM   #7
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
Being OCD I had to see where the leak was coming from so I reopened the fender well. I removed the electrical connector, outlet hose and drained the tank. Apparently I had the crack location wrong. After removing the previous attempted repair. I cleaned the area again and applied some liquid penetrant. The crack runs horizontal along the housing. This time I applied a marine/automotive grade RTV sealant. Hopefully this repair will last.
      02-12-2013, 02:03 AM   #8
rote
rote's Avatar
Drives: E90 325i
Hey, thanks for the write up and pics. I have the same problem and could not find a good write up on e90post.
      02-26-2013, 12:57 PM   #9
peeti
peeti's Avatar
15
Drives: 2011 M3 e90
Any chance this made a creaking sound when going over bumps when cold out? I have two symptoms right now, washer fluid emptied right after adding a full bottle and creaking on bumps - could be the reservoir cracked, could be suspension.
Curious as to what you heard if anything?
      02-26-2013, 01:51 PM   #10
SouthShoreM3
Passes everything but the gas station
Drives: 2010 E90 M3
I too want to thank you. I have had the same issue and brought to the dealer a while back and they could not detect any leaks.
Luckily it hasn't puddled recently and strangely enough it only puddles in warmer temps (summer for me).
      02-27-2013, 03:05 AM   #11
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
Its possible your reservoir could be loose. There is a 10mm bolt that holds it in place. No it does not get very could in south florida. I doubt the reservoir is cracked, however if yours is please post pictures.
      02-27-2013, 04:03 AM   #12
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
I replaced my pump after it starting leaking at the seals. This is relatively common. Got my pump for $68. Took 20 minutes to replace. No issue since. Rumor was that if you didn't use BMW windshield wiper fluid, this is common. I was running meth. The new pump had a different P/N than the old one and looked slightly different. I'm not sure if its improved or not.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      05-18-2013, 06:32 PM   #13
irishbrahmin
irishbrahmin's Avatar
23
Drives: 2021 X5 M50i
I just noticed a small blue puddle behind the right front wheel after returning from a long drive on a hot day. I have a service appointment scheduled for Monday morning!
2021 X5 M50i
      05-20-2013, 08:32 AM   #14
Sparkee
Stability is Overrated
Sparkee's Avatar
Drives: '08 E90 328i Sedan w/MT6
I have an non-M3 E90 but have exactly the same leak as Danny. From what I can tell there was no stress from the wires/hoses on the pump. All of my wiring/hoses were still attached properly (although maybe with the recent battery cable recall work they were in there and fixed it - since the battery cables run right through there). But, it is in a place where if the hose to the nozzles was too tight it could have caused that crack. The replacement pump looks significantly different, maybe BMW realized they had an issue and fixed it.
Total cost of repair for me with my BMWCCA discount is about $60 at BMW of Silver Spring (new pump, strainer, and some fender rivets) plus a couple hours of my time. It's not that difficult a job.
Also note, for my car without the headlight washers, the part # is 67127302589. I believe the number 67128377430 Danny provided is for the headlight washer pump:
2008 - BMW - 328I - N51B30A - L6 - 3.0L - GAS
BODY HARDWARE / WINDSHIELD / WIPER & WASHER COMPONENTS / Washer pump
67127302589 - Washer pump windshield
67128377430 - Washer pump headlamp
      05-20-2013, 02:39 PM   #15
NA V8
NA V8's Avatar
9
Drives: 2011 E92 M3 6MT
Sometimes the issue is not a leak but rather the overflow system discharging excess fluid (which is normal). I found this out after taking my car to the dealer to figure out why I was seeing some blue fluid on my car on a hot day. This only happened after I topped off the fluid in the reservoir (so the heat caused the liquid to expand).
Daily Driver: 2005 Lexus LS430
Fun Car: '11 E92 M3 6MT w/ M. Perf. Exhaust
Prior (all 6MT): '06 330xi, '09 135i, '11 550i, '13 335i
      05-21-2013, 02:45 AM   #16
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
Its been almost 4 months and my last repair is still holding
      05-21-2013, 08:53 AM   #17
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I had this happen to my car as well (a small puddle). However, it hasn't happen since, so I probably filled it to the top and it expanded.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      05-22-2013, 11:51 AM   #18
Sparkee
Sparkee's Avatar
In my case, the tank would slowly leak down to empty. So, expansion of the fluid clearly wasn't the issue. After pulling the tank, I hung the pump between two elevated hoses holding fluid/water, one still attached on the washer jet side the other a hose I had laying around. I could see the water leaking out of the side of the pump at a rate of about a drip every 5 seconds with this arrangement. It turned out to be a good way to prove it was the pump.
I am glad Danny's fix worked too...
      06-18-2013, 03:09 PM   #19
kwike92
kwike92's Avatar
Drives: 2014 M5 CP
I had this happen on my 05 325i, it seems like those pumps tend to leak over time.. I just replaced mine on my 325i and it cost me like $60.
2014 M5 Comp Package.
      07-21-2013, 07:38 PM   #20
peat_s
Drives: 2007 335i
I had the same problem with my 2007 335i. My leak is identical to Danny's. I ordered p/n 67127302589 from Tischer and am currently waiting for it to come in.
Thanks for the writeup! I would have never figured out where that WW bottle was :-)
Pete
      08-11-2013, 10:54 AM   #21
DigsZ4
Drives: 2007 Z4 3.0I
Pump Fix
Thanks for all the great pic's they sure help. I think I have the exact same issue on my Z4 and would liked to try your fix first before buying a new pump. I am a newbie to working on cars at any level and have a very basic question - does the electrical connector on top of the pump just pull straight off or is there a tab or something that I have to push to release it? As I said this is a first for me so I don't just want to yank on it, damage it and then have to replace that too.
Thanks
      08-12-2013, 03:04 AM   #22
Dannys M3
Dannys M3's Avatar
2008 M3  [10.00]
There is a tab in the back if your Z4 pump looks like my photo. BTW repair is still holding.
m3post
