12-25-2012, 06:12 AM | #1 |
Rep 68
F30 320i - N20 Tuning
Merry Christmas Everyone ...
Wonder what's the best available tuning for the Twin-power N20 320i (184hp) that can be Connected/Disconnected easily to avoid warranty issues during service. Most threads are talking 328i ... Would like also to know how much power the Kit will provide.
" if everything seems under control; you're just not going Fast enough " ??
12-26-2012, 05:50 AM | #2 |
Rep 68
12-26-2012, 08:24 AM | #3 |
Rep 9
Kelleners Sport:
http://www.kelleners-sport.de/b2b/in...tid=80&vid=865 German Engineering company, seems to be one of the most reliable tunes for the 320i on the market. |
12-26-2012, 10:41 PM | #4 |
Rep 44
I don't have any experience (yet) but see below for a couple more options:
BMW 3-er F30/31/35 320i 135kw/184PS - Engine: BMW2,0T135kw - fuel saving/performance tuning-Unit Tuning Box for BMW X1 / 1 Series / 3 Series 2.0i Twin Power Turbo N20
2013 BMW F30 320i - M-Sport, Alpine White, M Sport suspension and brakes, Sport AT, VSS, PDC, Xenon, High-beam assistant, Harman/Kardon, Extended BT, Rims 403M (summer 19") and 397 (winter 18"), M Performance: Exhaust, Rear Bumper Diffuser, Carbon fiber mirror caps, Carbon fiber rear spoiler, Black kidney grilles, Floor mats. 3M Brushed Black Metallic vinyl wrap roof.
12-27-2012, 11:52 AM | #5 | |
Rep 68
12-27-2012, 02:10 PM | #6 |
BimmerPost Supporting Vendor
4912
Rep 115,980
The JB N20 Stage1 tuning is compatible. Get the USB cable with it as they have 320 specific settings you load after installing.
Mike |
12-28-2012, 12:16 AM | #7 | |
Rep 44
Would you know if there are any benefits or downsides of using the 98 or 99 (RON) octane gasoline we normally use where I come from with the JB tune? Thanks!
12-28-2012, 05:17 AM | #8 | |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
Cleaner burning as far as manufacturers' claims go. My dealer started me off with a tankful of 95RON in my F30. I then put 98RON after using the first tank. I could feel a distinct performance improvement from the 98RON. Will ALWAYS use 98RON in my F30. 98RON recommended.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
12-28-2012, 01:05 PM | #9 |
Rep 68
The Highest RON we have here (Egypt) is 95RON ; Sure I won't be able to get all the power out of it !!
Still performance is great and acceleration is far better than my old E90 - 320i the N20 is an amazing piece IMO Thanks guys for all the good information ; Plz keep updating if there's higher outputs tuning kits
12-28-2012, 01:07 PM | #10 |
Rep 68
02-06-2013, 01:04 AM | #11 |
Rep 271
Since it is the same motor in the 320i as the 328i, only detuned, would it be possible to bring it up to the levels of a tuned 328i?
Or are the Intercooler and other bits not the same?
From houston? You should be on here then!
https://www.facebook.com/groups/HoustonBMWClub |
02-06-2013, 08:24 AM | #12 |
Usofstance
78
Rep 671
thats a good question but i bet a 320i can't handle that much power with out minor bolt ons/
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance United States Of Stance |
02-06-2013, 08:59 AM | #13 |
Rep 3,780
Pistons are different. So it will not match the capabilities of the 328.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
02-06-2013, 09:02 AM | #14 | |
Rep 44
Basically the 320i can't be brought up to the same figures as the 328i that easily as there are quite a few differences, i.e. compression ratio (11 vs. 10), different pistons, different backpipe (60,2mm vs. 75mm), software and maybe some other things people are not sure. Normally tuning companies quote about 220-230 horsepowers and ~325Nm what can be achieved with the 320i (with external units).
02-07-2013, 05:31 AM | #15 |
Rep 3,288
Drives: anything given a chance
Still amazes me how low-life's want to tune their cars engine and if something goes wrong (with the engine) expect the factory to pick up the tab. Grow a pair and be a man.
03-14-2013, 09:05 PM | #16 |
Rep 6
So, returning to jcastle's first question, have there been any actual results posted from the JB N20 Stage1 tuning chip installed on a 320i?
There has been quite a number of dyno results and discussions for 328i installs, but haven't seen anything for 320i. Are the numbers jcastle posted in his subsequent post accurate? |
03-16-2013, 07:45 AM | #17 | |
Rep 15
BMW has just announced a new entry level F30 3 series, the 320i. The 320i shares the same N20; TwinPower single turbo, twin scroll, 2.0 liter inline 4 cylinder engine as the 328i. The 320i is factory rated at 180 hp at 5,000 RPMs and 200 lb-ft of torque from 1,250 RPMs. Stacked next to the 328i with 240hp at 5000 RPMs and 255 lb-ft of torque from 1250 RPMs and the obvious question is what is the difference in the two engines. The first obvious answer is there is something in BMW's DME control software that limits the power, most likely by limiting boost pressure, on the 320i. That appears to be true as both the 320 and the 328 use the same DME hardware (PN - 12148604210) and the same engine control system MEVD 17.2.9. With a software tweak the likely difference between the 320i and the 328i we go in search of other changes that might limit the 320is ability to make the same power the 328i N20 puts down. The next easy target is the intake, exhaust manifold and turbo. Surprisingly they turned out to be the same part number. In fact the 320i and the 328i share the exact same part numbers for a majority of the engine components. Shared engine components between F30 320i and 328i Cylinder head - PN 11127624778 Connecting rods - PN 11247624616 Crankshaft - PN 11212212762 Intake manifold - PN 11617588126 Air box - PN 13717597589 Air filter - PN 13718507320 Intercooler - PN 17517618809 Radiator - PN 17117600520 Throttle body - PN 13547588625 HPFP - PN 13517584461 MAF - PN 13627602038 DME/ECU - PN 12148604210 Exhaust manifold/turbo - PN 11657642469 |
03-27-2013, 09:04 AM | #18 |
Rep 14
Hi, Iīm new at this Forum. I just bought the BMS Stage 1 for my BMW 320i. At first there was no change, the car was doing the same 7.2 second 0 to 60 from the factory.
But it seems that after 100 kms, the carīs computer finally adopt the new values and I could reach 0 to 60 in 6.6 seconds (full tank). The torque is notorious once the car takes 3rth gear reaching very fast to 100kms/h (or 60mph). I want to be sure that this isnīt a fake psychological feeling and that the Stage 1 did the 6.6 seconds. But, i was wondering if disconnecting car battery iīm going to ensure that the computer is getting the values from the BMS Stage 1? I guess 6.6 seconds in a factory 320i with full fuel tank itīs impossible,and the only responsable for that is the BMS Stage 1. I Have a video. Does anyone know how to disconect the battery? Regards, |
03-27-2013, 12:00 PM | #19 | |
Rep 356
03-27-2013, 02:11 PM | #21 |
Rep 356
that explains the skew in your timing. Your reaction time and/or enthusiasm easily account for the 1s difference. If an accurate timing to measure ur mods is what your really after invest in a performance meter like Gtech Pro SS or VBox performance box. All those stopwatches or smartphone apps just dont cut it with a sub 10s measurement the margin of error is too great
03-27-2013, 02:16 PM | #22 | |
Rep 14
Do you know haw to disconnect the negative battery cable? |
