Fried Xenon Ballasts
11-23-2012, 02:39 PM | #1 |
Rep 541
I had a bulb go out on my 06 330i and verified bad bulb by swapping bulbs right to left. So I did a stupid thing and ordered some cheap Chinese D1S bulbs from eBay and installed them only to find out that nothing worked at all. Putting my old bulb (the one good one) back only reinforced my fear that I'd done some bad damage to the ballasts. Searches here and other forums confirmed my fears. I found out the hard way that BMW ballasts aren't very tolerant of cheap bulbs.
Anyway, I've removed the old ballasts and could immediately smell that rancid odor that they mix with the smoke they compress into chips. Since they were obviously fried, I couldn't resist the temptation to cut one open. It appears that a discreet component (probably a filter capacitor) decided to let its smoke out (click on image for hi res): Full board: Ballast on headlight: Inside the headlight bucket side of ballast: So it seems that I can pay $477 each for these, or attempt a repair with a $0.05 capacitor. The only problem is that since it's fried itself into oblivion, I have no idea what the value might be. Does anyone have a clue? Does anyone have a bad ballast with that component intact that could pop it open to see what value is printed on it? |
11-29-2012, 08:00 AM | #3 |
Rep 541
OK, I decided that I'd give a try at retrofitting a cheap aftermarket ballast into my system. My research determined that there are no aftermarket kits with D1S bulbs, but D2S bulbs seem to have the same size and shape where the bulb fits the socket, so I ordered up a kit from eBay with 4300K bulbs, slimline ballasts and all the harnesses and decided to go from there. Here's my photo documentation of the process. I wanted to make it as clean as possible without cutting/distorting anything should I decide to go back to stock in the future (like if I find a decent OEM ballast set cheap). Click on any photo for full resolution.
First, I removed the socket from the old ballast board so I wouldn't have to cut the original feed connector: Next, solder up the connection to the harness for the new ballast: Heat-shrink tubing is an electronic hobbyist's best friend: Completed harness ready to plug into stock headlight connector: (Continued in next post) |
11-29-2012, 08:26 AM | #4 |
Rep 541
Plug it all in to make sure it all works (it does!):
The D2S bulb with it's connector is slightly taller that the D1S. That might be a problem A zip-tie should take up the slack: Acceptable fit: Now I have to seal up the box to keep moisture out. Time for a little woodworking: A little sanding and it fits snugly with the original o-ring: Now to make a complete cap: Epoxy: the other best friend of a hobbyist: Clean up the excess: Now that it's set, drill a hole for the wires (I'll plug this with RTV silicone once it's installed): A little more sanding: And a coat of paint to seal it: A metal strap and it fits nicely in the original slot. Now to put it all back together: |
11-29-2012, 10:10 AM | #5 |
Rep 1,794
Drives: 06' E90 330, 20' F97 X3m
Nicely done man. Good fix for a common issue w the cheaper replacement bulbs. I'm assuming you do have error messages on the dash though right? Nonetheless job well done w extra attention to detail
LIVE FAST..DRIVE FASTER!! |
11-29-2012, 11:20 AM | #6 |
Rep 541
No warnings. There is only the power in (+12V and GND), i.e. no logic feedback of any kind as far as I can tell, so apparently the FRM only looks for a current draw during the bulb check. I assume the aftermarket ballast draws about the same current so the FRM is happy.
11-29-2012, 02:00 PM | #7 |
Rep 54
Happend to me too man now the cheapest ballast i found was $320 and im still thinking if im going to buy it or look for cheapest one around. Dont have one headlight for 3 weeks now lol
