M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      10-21-2012, 05:08 AM   #1
dr.skp.ortho
dr.skp.ortho's Avatar
Australia
15
Drives: 991 911 Carrera S, F06 M6 GC
SLX Vs Edge
Is there any difference between Castrol SLX Professional LL01 5w30 and Castrol Edge Professional LL01 5w30?
Thanks
Porsche 991 911 Carrera S
BMW F06 M6 Gran Coupe
BMW F15 X5 5.0 Xdrive M Sport.
Mercedes C250
      10-21-2012, 07:33 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
Castrol Edge Professional is better (maybe simply a marketing thing ?) & newer.
It has 'API - SL' rating which is what BMW recommends.
The SLX Professional is rating API - SJ which is lower than SL.
Before buying, just make sure the oil is marked 'Made in Germany' and it has the BMW LL-01 stamping at the back of the bottle. Don't buy the one the is Made in US.
Thanks
      10-21-2012, 11:55 AM   #3
stealth.pilot
Knight Commander
stealth.pilot's Avatar
Drives: 2014 911 Turbo S
What do you think of AMSOIL Signature 0W-30?
This post seems to rate it highly - based on the data. Mobil 1 looks pretty good in this test too.
http://www.bimmerforums.com/0w30/
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      10-21-2012, 03:53 PM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
I post the finding in another thread .... if you go to the bottom part of the page, the AMSOIL answer / comment is there .... Note: the article does not have a published date, therefore, I am not sure if the status has changed.
http://superiorvehiclerepair.com/bmw...f-bmw-oil.html
As far as Mobil 1, 0W40 European Formula is the only one recommended for BMW oil top up or change.
      10-21-2012, 04:14 PM   #5
stealth.pilot
Knight Commander
When I look at the Castrol Specs, the 0W-40 seems to meet BMW spec better than the OW-30. Specifically ACEA A3/B4.
When BMW does the complimentary break-in oil service at the VPC, what will they use?
      10-21-2012, 05:12 PM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
Mine was changed with BMW Performance (aka Castrol) 5w30 (in Canada). Therefore, for US, it would be the same ...
      10-21-2012, 07:46 PM   #7
stealth.pilot
Knight Commander
Should I take my own oil if I want a 0w-40 or 0W-30 oil?
Wouldn't that be better. I heard if you like to drive in a cold start then the 0W oils are better.
      10-21-2012, 07:55 PM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
True. "O" is better for winter. But then, the oil change is free, why spend more if you don't have to.
      10-22-2012, 08:48 AM   #9
dr.skp.ortho
Australia
15
They are both API SL rated and ACEA A3/B3/B4
Mercedes C250
m5post
