can anyone help me out with my logs jb5 e85
09-28-2012, 09:11 PM | #1 |
Rep 646
i just did some logs of 3rd gear an 4th with some e85 an 91 i get check engine light
heres my logs wat settings do i change? or wat do i mess with? |
09-28-2012, 09:37 PM | #5 |
Rep 646
09-29-2012, 08:57 AM | #8 |
Rep 7,377
lol you can actually save the log as jpg as well no need to take a picture with the phone :-)
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
09-30-2012, 07:42 AM | #10 |
Rainbow Racer
1008
Rep 2,540
to me, fuel trims are kind of high in the upper RPM ranges. Do you have CPS enabled? Looks like you do with the low ignition advance curve.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
09-30-2012, 03:51 PM | #11 |
Rep 290
Did you read the code to see what the CEL was about? Probably due to the fuel trims being maxed out.. How much E85 did you put in? I'd stick with 30% and try again. This calculator at the bottom of this page helps with getting the proper mix: http://e85prices.com/milesperdollar.htm
