E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > BOV flange adapters
      09-26-2012, 08:26 AM   #1
Redrkt503
Redrkt503's Avatar
31
Drives: E92 335is
BOV flange adapters
Hey guys, I have a tial bov now but on ATP's website saw an adapter to make a tial flange to say an HKS flange...anyone have experience with these?
2011 335is "Redrkt" 6 MT
DocRace 6266 Single Turbo - Fuel it stage 3 LPFP - Fuel it PI - spec stage 3+ clutch - mfactory SM flywheel - 100% E85 - VRSF 7.5" intercooler - VRSF charge pipe w/ HKS BOV - JB4 - MHD back end flash
768 whp 695 ft lbs - E85 - 32PSI
      09-26-2012, 11:03 PM   #2
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I am looking into this also, I have a tial and I want a synapse and I have seen adapters (SB001.6A) for these as well....just need confirmation they work well. I have a ER CP and need to know if the synapse will fit like the tial (I am guessing ER puts there flanges in the same spot regardless of the BOV type). I am guessing. Would just use my existing tial clamp for his flange? I am just trying to avoid buying another CP lol!!
http://www.amazon.com/Synapse-Synchr.../dp/B0094BLMGM
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      10-01-2012, 08:34 PM   #3
Redrkt503
Redrkt503's Avatar
31
Drives: E92 335is
anyone?
      10-01-2012, 08:38 PM   #4
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
anyone?
will let you know Wednesday, I got the synapse BOV with the Tial adapter.
      10-02-2012, 10:25 AM   #5
Redrkt503
Redrkt503's Avatar
31
Drives: E92 335is
Thanks man! I wanna pull the trigger on an hks
      10-03-2012, 11:16 PM   #6
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I got the synapse flange...going from tial to synapse and it sealed better than the tial did LOL!! Worked flawless!!
      10-04-2012, 12:01 AM   #7
Redrkt503
Redrkt503's Avatar
31
Drives: E92 335is
sweet, going to pull the trigger on it
      10-04-2012, 12:10 AM   #8
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
i would!
      10-04-2012, 02:19 PM   #9
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Car seemed great with it....sounded great but is leaking...I called ER and they said the adapters never work be use they are a bit to big....I data logged last night and I Was way under target. I believe the the flange has a slight movement and under heavy boost leaks...I was only hitting 15 psi when my target was 19-20......before this flange I hit 18-19 all day long. I also noticed with the flange I can move the BOV...that should not happen.
      10-05-2012, 02:17 AM   #10
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
this looks to be firmware related...I am testing out firmware and now car hit 18-19 psi no problem 5 runs in a row...flange is good.
e90post
