09-19-2012, 02:57 AM | #1 |
I plead the 5th.
523
Rep 1,519
0-60 in 4.xx Seconds
For those of you unaware, the P3Cars vent gauge has a 0-60 function that will clock exactly that - your 0-60 acceleration (on top of many other things it does). Basically, when you are stopped, the gauge will read "Ready" and the moment the car moves, a timer starts. Once your car hits 60MPH, the timer stops, and voila - there is your 0-60 time. Pretty cool (and addicting) feature!
Well today I finally had the chance to install the BMS Stage 1 tune on my N26 328i. When the opportunity arose I had to do some 0-60 runs! My car is a standard 8spd N26 328i currently on the OEM 17's w/runflats with some mods from the lovely Evolution Racewerks & Burger Motorsports. Current power mods are: -Evolution Racewerks Intake -Evolution Raceworks Downpipe -BMS N20 328i Stage 1 Tune On a level gravel road (mediocre traction), one passenger, and all windows down I was able to clock 0-60 in 4.91 seconds earlier today. With better tires, a good road, and no passengers, I'm really excited to see what happens. Just thought I'd share my experience, the N20/6 motor is quite potent! If anyone else has 0-60 times recorded on level roads (in other words, no cheating :P), share in this thread
-Matt
09-19-2012, 10:25 AM | #2 | |
Rep 886
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
09-20-2012, 02:10 PM | #4 |
I plead the 5th.
523
Rep 1,519
Got 4.90 on the way home last night, still not ideal conditions though. Need better times!
Nobody else has the P3 Gauge?
-Matt
09-25-2012, 12:29 PM | #6 |
I plead the 5th.
523
Rep 1,519
Was indeed brake-torquing. Light is still on :/
-Matt
09-25-2012, 10:47 PM | #7 |
I plead the 5th.
523
Rep 1,519
No passengers, about 72 degrees, windows up & A/C off. Only mod change since last time was key hole cover. Same location as previous times. Really makes me want to hit the strip!
-Matt
09-26-2012, 10:13 AM | #9 | |
Rep 3,780
We are talking nearly a 1 second improvement from 30whp.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
09-26-2012, 11:19 AM | #10 |
208
Rep 1,161
I plugged in some numbers here:
http://www.060calculator.com/ These types of calculators are ballpark at best, but fun nonetheless. To get the types of numbers the P3 is reporting you would need 320 hp, even with the most generous weight and transmission available on the calculator: Horsepower (at the flywheel): 320 Curb Weight lbs: 3400 Drive TypeTransmission: Dual Clutch 0-60 mph 4.619 seconds More realistically, with an automatic trans and 3500 lbs, you would need 395 hp to do a 4.6 0-60. Again, this is an on-line calculator, so it's FWIW. |
09-26-2012, 01:23 PM | #11 |
Rep 3,780
Car is probably making 270whp, 320 at the crank is not very far off.
09-26-2012, 02:11 PM | #12 | |
I plead the 5th.
523
Rep 1,519
Actually, if we look at the numbers, this almost seems plausible. When ER dyno'd their N20 F30 with same mods, it was putting down ~270whp & 290wtq. Assuming 15% drivetrain loss, 270whp puts us at ~318bhp. My car is running same mods but with N26 motor, so may differ slightly outside of that. The other big factor outside of transmission type, weight, and horsepower is gearing, which can't as easily be considered via simple metrics. FWIW, when you plug in the numbers for a 370z Auto, the calculator gives 0-60 in 5.2 while real life tests put this car at 4.7. Still a fun calculator though! Either way, some easy mods and this "240bhp" motor really livens up Edit: Actually, a coworker brought up a good point. These HP & weight numbers seem pretty close to E46 M3 numbers. Maybe a few less HP but a bit more TQ. Bench racing FTW
-Matt
04-29-2013, 08:25 AM | #13 |
Rep 1,436
umm I got 4.9 avg with only the ecu 3.3 psi over stock RON92 I guess you should crack up the boost to 4.5 psi.. I read someone had the 125i with n20 engine he opened boost to 6 psi he managed to pull 285 whp !!! only ecu so i guess with ur mods u'll get more
04-29-2013, 01:41 PM | #14 |
Rep 20
Bms has a fix for the light btw... I also have a n26, Does ER have a downpipe for the n26, i keep hearing the n20 dp wont fit to the midpipe.. ?
04-30-2013, 11:07 AM | #16 |
Rep 20
04-30-2013, 11:12 AM | #17 |
Rep 1,400
I agree with you using that PS gauge is not acurate at all for acceleration numbers. But I dont think its any worse the 335i PPK people saying 20 hp makes the car stupid fast.
04-30-2013, 11:29 AM | #18 |
Rep 3,780
Perception and numbers are two different things lol. Ppk people are not showing 0-60 of 5.0 going down to 4.0 lol.
04-30-2013, 12:14 PM | #19 |
Rep 1,400
04-30-2013, 02:17 PM | #21 |
Rep 3,780
05-04-2013, 09:26 PM | #22 | |
Rep 12
