E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > ***ptf S1+ E50 Ftw***
      09-18-2012, 11:22 PM   #1
VNeBLOB42
VNeBLOB42's Avatar
Drives: 14' GMC Terrain SLT-2
007 335i E92  [7.66]
Thumbs up ***ptf S1+ E50 Ftw***
Hey enthusiasts,
I just wanted to share my Dyno results for PTF E Tune COBB S1+ E50 (50% Ethanol).
2007 E92, current @ 51k miles.
Max Run at 367 whp @ 394 tq.
130 whp @ 133 tq Delta!
Special thanks to Dzenno at Pro Tuning Freaks for an outstanding job and getting the MAP versions revised and returned quickly. Jake and Dzenno @ Pro Tuning Freaks are great to work with and would recommend them highly.
These results were based upon many factors, thus numbers can vary depending on Dyno type, mods, tune, gas, etc. You get the idea.
I began this endeavor mid February 2012, where I completed a fully stock Baseline Dyno run.
A Dyno Dynamics aka Heartbreaker Dyno was used. This Dyno uses SAE corrections, thus the read out are lower than other Dynos. But the important part! Are the delta’s!
Baseline Run:
Max 231 whp @ 257 tq
4th gear AT (DS Mode)
+- 60 deg Outside Air
Hood up
+- 5-8 min. between runs
42,500 miles
Since my goal is to keep stock DP’s until warranty and 1st SMOG is up, I decided to get maximum power with COBB S1+ in the meantime.
March through August Mods: ( took longer than expected )
Spark Plugs under maintenance
Walnut Shell Blasting
CPE DCI
COBB Tune
ETS FMIC
ER CP w/ TiAL BOV
Now of course, the fun part. After dialing in the E Tune I took it back to the Dyno shop.
PTF S1+ E50 Dyno Runs
Run 5 Blue 367 whp @ 394 tq
Run 9 Red 360 whp @ 390 tq
Run 10 Pink 362 whp @ 397 tq
Green Baseline
4th gear AT (Manual Mode)
+- 77 deg Outside Air
Hood up
51,500 miles
A Delta of 130+ whp @ 133+ tq.
Fuel blends @ 8.5 gallons of E85 with 7.5 gallons of ACN 91.
Overall I am very satisfied with these results and it shows that there is power to be made with a Stage 1+ 335i. Granted the fact with Stock DP’s, ACN 91 and we didn’t push the limits, there is still more ponies to be made.
Thanks,
Vince..
__________________________________________________ __________________________________________________ ______________________________________
***UPDATE*** September 26th, 2012 @ 10:00 pm PST
As promised below are my DynoJet Numbers.
Max Run:
415whp @ 443wtq
Baseline:
291whp @ 296wtq
Keep in mind, this baseline is COBB MAP 0, with current MODs and E50.
Delta of:
124whp @ 147wtq
Not to be a glorified Dyno Queen, I feel there is still room for improvement on these runs. The tech had some difficulty with WOT and we didn't hit WOT till 4800 RPM. I didn't reach max boost or timing, but anyway it is what it is, these are just numbers.
$20 a run was beginning to be an expensive learning curve for Mr. Tech. not used to AT. . But overall I was very happy with with MCE Racing, they are good and knowledgeable people.
As you can see; 48 whp @ 48 wtq difference between the Dyno Dynamic vs. DynoJet. Either way the car feels the same no matter what Dyno I use. But for bragging rights, I'll say i have a 400 whp car.
thanks,
Vince
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50
Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI
      09-19-2012, 01:54 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
Impressive results! Congrats
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      09-19-2012, 02:14 AM   #3
Brey335i
Drives: e46 ///M3
PTF doing it right!
      09-19-2012, 08:15 AM   #4
EJ_3
EJ_3's Avatar
Drives: e92 335i, e34 525i & e60 530i
2007 BMW 335i  [8.34]
2016 Ram 1500 Sport  [8.00]
1994 BMW 525i  [10.00]
2007 BMW 530i  [8.66]
Excellent results. I'm tempted to give these guys a chance, but I don't want to lose my 26/34 MPG. Only if there was a way to have great power and fuel consumption.
      09-19-2012, 08:17 AM   #5
enrita
enrita's Avatar
Sweden
161
my car on E50 has dreadful mpg. if you are off boost is fine but since i am always on boost ... your mpg will take a dive for sure.
      09-19-2012, 08:24 AM   #6
VNeBLOB42
VNeBLOB42's Avatar
007 335i E92  [7.66]
Thanks!
Originally Posted by Brey335i View Post
PTF doing it right!
Yes they are.
Considering the ethanol, your mpgs will .drop a little, but you can request more than 1 MAP, have a daily commuter, and a weekend MAP. May be a pain in the but to keep changing the fuel blends though
+1
      09-19-2012, 08:46 AM   #7
TotalBlackout
TotalBlackout's Avatar
Drives: 2008 TiAg 335i
How are you getting 26/34?
I think I get like 20/27.
2008 335i Coupe TiAg - Cold Weather - Premium - Sport - Style 230 19's - SatNav - Active Steering/Cruise - Comfort Access - PDC
      09-19-2012, 09:11 AM   #8
Willizm
Willizm's Avatar
24
Drives: 2009 335Xi and 01 Trans Am WS6
Manny for shits and giggles you should try to run the cobb of the shelf e30 tune to see if you like it. If not then you are only out a little bit of time testing it, but if you do like it then you can get ahold of PTF to get even more out of it. Also, e85 mix tunes will show worse MPG the more ethanol content you go. You could do a conservative e25 tune and not be too bad off from your current MPG.
335i - stock for now
Escalade - Urban Assault Vehicle
T/A - Forged ls1, PT8285 turbo, heads, cam, 4l80e w/Transbrake, s60 rear on e85.
      09-19-2012, 09:32 AM   #9
EJ_3
EJ_3's Avatar
6 m/t and tuned while cruising. I was getting about your gas mileage stock, but after it was tune, it went up... as long as I'm not driving like a mad man. The secret to good gas mileage is in your foot .
I thought about running the OTS E30 map but after hearing Jace talking about his gas mileage dropping, it turned me off. I'll give it a shoot after I move to Vegas permanently since there's no 93 octane to continue running my ST2 Aggressive.
SN: How are you enjoying the 2 step with no lift shift on your 135?
      09-19-2012, 11:00 AM   #10
jayzF30
Drives: '07 335i, '09 M3
Amazing numbers! When you go with downpipes it will open up even more. Great job PTF!
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock
      09-19-2012, 01:54 PM   #11
Willizm
Willizm's Avatar
24
Yeah going from 91 to e85/91 is a step up although i'm pretty much stock except for my DCI and clutch stop. I haven't tested the 2step until I get catless dp's and midpipe installed. Just wired it up for future use. I'm still getting the e85 blend adapted before I start testing the NLS. I have it configured and it should work, but won't know until I try it. Are you in Vegas yet or still in Florida?
      09-19-2012, 02:21 PM   #12
VNeBLOB42
VNeBLOB42's Avatar
007 335i E92  [7.66]
Yes there will.
Does anybody know the TQ rating on AT? That would be my only concern of going higher.
      09-19-2012, 02:35 PM   #13
enrita
enrita's Avatar
Sweden
161
Dont worry about the AT on stock turbos. Just dont go wild on launches from a dig.
      09-19-2012, 02:42 PM   #14
EJ_3
EJ_3's Avatar
Still in Florida until the last week of November.
      09-19-2012, 03:07 PM   #15
Laid Black 335i
BMW
Laid Black 335i's Avatar
Drives: 2007 BMW 335i (6MT)
Nice numbers! Get some DP's asap!
      09-19-2012, 04:06 PM   #16
JStang
JStang's Avatar
562
Drives: FDB M3 CS
That doesn't sound like much fun.
      09-19-2012, 04:59 PM   #17
Mangler
Mangler's Avatar
15
Drives: 08' 335i, ZHP 330i
88 .  [0.00]
2008 BMW 335i  [0.00]
E50 FTW is right. This is my personal pro tune from the S1+ map. I don't know how accurate the VD is but its same stretch of road with same weather conditions. My deltas are pretty nice too!
T
      09-19-2012, 05:11 PM   #18
King mode
Drives: 335xi
Thats great man. I need a FMIC...
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock
13.10@106.01 w/ 1.86 60' (5,800' altitude)
      09-19-2012, 05:17 PM   #19
VNeBLOB42
VNeBLOB42's Avatar
007 335i E92  [7.66]
Thanks good to know.
      09-19-2012, 05:22 PM   #20
VNeBLOB42
VNeBLOB42's Avatar
007 335i E92  [7.66]
Yes, I would get FMIC before DPs. Well specifically in warmer climates.
I didn't have the proper cooling fan when dynoing thus was loosing some power. That's why you.see the difference between run 1 and 2. If I had the proper fan, as one directly in front the inter cooler, I may have seen 370's.
      09-20-2012, 10:01 AM   #21
mystuffisbest
mystuffisbest's Avatar
Drives: 335I E92 Alpine
Hey bud found your post and was good chatting with you last night at the meet. Looking forward to the next one. Justin
      09-20-2012, 10:09 AM   #22
VNeBLOB42
VNeBLOB42's Avatar
007 335i E92  [7.66]
Awesome!
I would send PM, but I am partially banned. LOL
Sent you a friend request but not sure if it went through the admins got me on lock down.
e90post
