headlight replacement
09-07-2012, 11:47 PM | #1 |
Rep 6
First post here. Just parked my "new" '06 325i in the garage only to notice the adaptive headlight failure warning on the dash. I did quite a bit of searching and could not come up with an answer so here it goes. It seems the drivers side headlight is stuck. It does not auto level when I start the car and it does not move left to right.
I don't really want to take it to the dealer to pay $60 for them to tell me I need a new headlight. I also don't want to put $150 into a module and have that not be the issue. I found a headlight from a salvage yard for $250 that is guarenteed to work. My question is; can I plug this OEM headlight from the salvage yard into my car and have it work properly? I know if I bought a module I would need to have it programmed. Will the replacement OEM headlight need to be programmed as well even though it was on another vehicle working? Is the programing vehicle specific? Thanks for the help and I apologize if the first 4 replies are of links to threads where my questions are answered in the subject line. I'm sleep deprived and frankly a little upset when I saw 4 digit numbers being thrown around in the "my adaptive headlights failed" threads. |
09-08-2012, 06:07 AM | #2 |
Roll Tide Roll!
36
Rep 270
I am having the same issue and its at the dealer getting fixed as we speak. They are replacing the headlight and module and it does need to be programmed. Cost is around $1800 for parts and labor. During the reprogram my cluster stopped working so the entire car needs to be reprogrammed. Was told it can take up to 18 hours.
Only silver lining for me is the dealer that I bought the car from is covering all the costs since it was out when I bought it 3 weeks ago.
"You should never underestimate the predictability of stupidity."
09-08-2012, 10:40 AM | #3 |
Rep 2,731
assuming your existing headlight module is ok and the headlight stepper motors are what is bad, you can unbolt the good module from the bottom of your existing headlight and move it over to the new headlight. you won't have to reprogram it.
if the existing module is bad, then you are going to have to reprogram. |
09-08-2012, 11:13 AM | #4 |
Rep 43
Can some one describe to me what the headlight module is? Is this the same as the Control Unit? I ask because I too am having headlight issues. My issue though is that my Control Unit is bad. I was under the impression that I could buy one second hand and it would not require a program? Don't intend to thread jack here, just had a relevant question and it seems you guys know what you're talking about.
09-08-2012, 11:51 AM | #6 |
Rep 2,731
The module bolted to the bottom of the headlight is called an SMC II
It is referenced in this thread.... http://www.e90post.com/forums/showthread.php?t=594897 Do a few searches with SMC II |
09-08-2012, 11:54 AM | #7 |
Rep 2,731
and the diagram for modules is here....
http://tis.spaghetticoder.org/s/view.pl?1/10/75/22 long story short.... it looks like the FRM (footwell module) controls the SMC (headlight motor control module), which then controls the headlight motors You can interchange used SMC modules without programming. New ones need to be programmed because they are blank. It attaches under the headlight (small metal box). Must be same side though to do a direct replacement without reprogramming... left=left , right=right |
09-08-2012, 04:39 PM | #8 |
Rep 6
Is it likely that the the control unit would come with the used headlight? I'm having trouble getting a response from the guy selling it. If it doesn't it's a 50/50 chance either way whether I buy a control unit or a headlight.
Is there a way of telling if it's my control unit or the motors that are bad? |
09-08-2012, 06:32 PM | #9 |
Rep 2,731
yea if you want to troubleshoot whether it is your headlight motors (stepper motors) or if it is the module that controls them, switch them.
you would have to remove both left and right side headlights and change the SMC module with the opposite side. the lights will probably act in reverse of how they should but if the light moves, then you know that the motors are good and you need a new SMC module. flip them back to the correct side and buy a used module so you dont need to recode. if your light does not move, then it is safe to say the motors are bad. order a new headlight. anyway... if the guy won't give you a direct answer about if the light comes with the module or not, ask him to take a picture of the headlight assembly. the metal module box is on the bottom.... part number 3... looks like this.... anyway to recap... flip your current SMC modules left to right, and right to left. see if the dead headlight starts moving and if the working one stops moving. if so, then the module is bad, flip them back and get a used module to replace the dead one. if flipping the modules has no effect then the headlight motors are likely bad and you can reuse your current modules and just get a new headlight. make sure any module you buy used if for the correct side (l or r) otherwise you will need to recode it. |
09-08-2012, 07:48 PM | #10 |
Rep 43
So I'm sorry this is really confusing to me now. Is the "module" the same as the control unit? Is the SMC module shown in the parts diagram above? What is its part number?
09-08-2012, 09:51 PM | #11 |
Rep 2,731
the car has many modules, the SMC module is the Stepper Motor Controllor module. It controls the stepper motors in the headlight. I have no idea what the "control unit" is, it could be the FRM footwell module because that unit takes a lot of inputs from things like the steering angle sensor and speed sensor, and then passes that info to the SMC. it could also be the SMC itself.
09-09-2012, 11:36 AM | #13 | |
Rep 2,731
08 CONTROL UNIT XENON LIGHT 2 63126948180 $413.73 that is definitely a ballast like you said, it has no control of the motors for the adaptive headlight movement. |
09-09-2012, 10:15 PM | #14 |
Rep 6
I'll be swapping units tomorrow to try and troubleshoot. I have a feeling my passenger side light isnt't moving left to right either even though it auto levels. Are the units that control auto leveling and left to right motion one in the same or are they seperate?
02-12-2014, 11:06 PM | #15 | |
Rep 2
More Alc Woes
02-15-2014, 01:45 PM | #17 |
Rep 2
