Car overheating???
09-06-2012, 05:22 PM | #1 |
Rep 135
Car overheating???
So my car is acting very odd. out of no where the engine overheating warning is coming on the fans kick in, it sounds like a jet engine and my car goes limp. the actual temp gauge in my car is reading 160-200 and the engine doesnt feel hot at all what can the issue be right now I'm stuck at work and I don't know what to do because it won't drive.... Is it a faulty sensor can I get reset it do I can drive home?? Please help
09-06-2012, 05:26 PM | #2 |
Rep 3,854
Drives: 330i, 135i
If its overheating dont drive it. Have it towed to a shop asap. Most likely is the water pump/thermostat. hopefully im wrong. Good luck and keep us posted.
09-06-2012, 07:13 PM | #4 |
Rep 2,554
the temperatures that you are seeing (160-200) are the oil temps, not the water temps.
how many miles on the car? water pumps are pretty much maintenance items on the 3 series |
09-06-2012, 07:33 PM | #5 |
Rep 1,597
It sounds like it...
BEFORE: 130i N52 (2006-2011)
NOW: 335xi N55 (2011- ) |
09-06-2012, 07:39 PM | #6 |
I <3 My E93
180
Rep 3,259
im 100% sure its your water pump...how many miles you have? im at 67,xxx miles and my water pump went bad and i had the engine overheating warning lights come on and yes my car sounded like a jet engine bc the fan noise was super loud...
if your not under warranty thats a $1,200 fix....GOOD LUCK
Bagged and Wrapped E93 335i
09-06-2012, 09:21 PM | #7 |
Autobot
Rep 454
Drives: E90 325i Auto~NO~Go
Yes, 100% sure that it's your water pump. Same exact symptoms that I experienced.
09-06-2012, 10:32 PM | #8 | |
Rep 1,627
. your oil temp gauge is reading only 160-200? That is super low. Mine runs 230 all day long. |
09-06-2012, 10:45 PM | #9 |
Rep 135
just got it towed to the shop seems like just in parts a new water pump is around $600 this is not going tot be fun i have 57k miles so nope my car is no longer covered
09-06-2012, 10:58 PM | #10 |
Autobot
Rep 454
Find an independent shop if possible and shop around now that you know that it is indeed the WP.
09-08-2012, 02:59 AM | #12 |
Autobot
Rep 454
The good thing is that all e90 will experience this at around the 80K miles, might as well chalk it up as part of preventative maintenance. I know there are the lucky few who managed to clock 150K+ miles on the original water pump but I'm not one of them, haha.
09-22-2012, 05:16 PM | #15 |
Rep 9
80k is around the time alot of accessories break down for many cars, ie water pump, power steering etc. If you can source your own parts (pump, gasket, O-rings, coolant etc) and have decent mechanical skills, you can do it yourself and save a bit on labor.
