New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      08-21-2012, 02:18 AM   #1
ymdd
Drives: not fast enough
Maximum power that the DCT can handle
What is the max power that the DCT can handle? And what is the maximum power that the N54 can produce?
      08-21-2012, 06:48 AM   #2
The_Hulk
Drives: Alpine White 35i
BMW Z4 35i  [0.00]
http://www.getrag.com/en/252 will give you an idea what the DCT can handle.
The N54 can reach up to 550hp with mods like FMIC, DP's, race gas, meth kit, aftermarket exhaust and a remap.
The question is if the DCT can handle this? I'm not sure but it will cost you alot of money if something goes wrong.
      08-21-2012, 12:07 PM   #3
javol
Italy
20
Drives: Z4 35i DCT
With my setup i should be around 510 wheels Nm peak.
99% it's only a sensation... because theoretically I’m still far from the DCT torque limit...
…but when i floor @ mid-range in 6th or 7th gear on the highway it seems that the clutch slips a little, little bit.
Anyone else experimenting the same?
2012 Z4 35i DCT Black/Beige - 20" Vossen CV3, PB-Brake BBK, ///M Front Bumper, ///M Steering Wheel, Led Angel Eyes, Black Grille, Short Antenna - Tuning: JB4 Map 2, Custom Made 3" DPs & MPs, BMS Dual Intake - Desire list: 3D Design Front Lip, Meth Kit, FMIC.
      08-21-2012, 10:25 PM   #4
z4z4z4
z4z4z4's Avatar
Drives: 2002 M3
Design and materials have been trying to minimize clutch slippage for a long time. IF you play you're gonna pay. Every MT e89 will be replacing their clutches between 30k and 100k depending on the nut behind the wheel. Sport and Sport+ in DCT will shorten the life compared to Normal. Clutch preservation and DCT torque handlng limit are reasons why DSC OFF, long press, resets the shift speed program to slowest Normal mode. I only drive with DSC Off so when I make 400+ whp I'm not also banging the clutch in fast and super fast shift modes of Sport or Sport+. Most of us program boost in 1st and 2nd gear to 9psi and 12 psi respectively to save tires and then let 3rd and 4th target 17psi ...and those with meth do not flow at all in 6th and 7th gear to save 400+ wtq from trying to translate through the DCT at high rpms. My M3 clutch slips in my SMG but it has 104k miles. Be glad we don't have the $20K clutch replacements as the Carrera GT that only last 15-20k miles if driven correct.
http://teamspeed.com/forums/gt/5821-...placement.html
Sold 2011 Z4, kept 2002 M3
PM for various e89 parts 4sale.
      12-06-2012, 05:33 PM   #5
SpeedDemon7
SpeedDemon7's Avatar
70
Drives: 2015 F80 M3 Austin Yellow
I have 17,000 (hard miles) on mine and its running strong still with 400+ torque
2015 F80 M3 DCT : JB4 : Gintani DP : METH : BMS INTAKES : Upgraded Turbos : GTS DCT Flash
11' Z4 35i Procede REV 3 SOLD
2007 e90 335i 6MT:Procede REV 3: Raceland 2.5": VRSF 7":VRSF CHARGE pipe: Walbaro 255 inline: ACT 6 Puck: 100% e85
Garage: 2015 M3 : 2007 M5 : 2016 X1 : 2003 X5
zpost
