08-06-2012, 11:12 PM | #1 |
Supreme Allied Commander
3837
Rep 54,339
Drives: F80 M3
>>> HP Autosport <<< aFe Stage 2 GT E82 1M Closed Design No Hot Engine Air!
Producing 14 max horsepower and 27 lbs. x ft. torque, this radically different Stage 2 sealed cold air intake system is engineered to let maximum air in while keeping engine heat out.this intake system smoothly directs increased air flow for improved volumetric efficiency and maximum performance. So effective is the design that Intake Air Temperature (IAT) at normal running speeds with this aFe intake system is 11 degrees lower than the factory intake. Easily accessible with a satin black powdercoated aluminum cover, an washable/reusable conical air filter is enclosed in a molded plastic housing and mounted on a oval intake tube that smoothly supplies maximum air to the twin turbos. The full effect of this system cannot be felt or tested on stationary dyno and can only be fully appreciated on the wide open highway.
02-19-2013, 09:30 PM | #6 |
3837
Rep 54,339
Drives: F80 M3
AFE N54 Stage 2 N54 intake, GIAC, Wagner FMIC
AFE N54 Stage 2 N54 intake, GIAC and Wagner FMIC, a great combo for power and reliability!
02-28-2013, 08:24 PM | #8 |
3837
Rep 54,339
Drives: F80 M3
03-03-2013, 06:49 PM | #9 |
Rep 184
07-28-2014, 04:31 PM | #11 |
3837
Rep 54,339
Drives: F80 M3
08-11-2015, 11:59 AM | #15 |
3837
Rep 54,339
Drives: F80 M3
