F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Initial Dynos of JB N20 Tuner
Extreme Powerhouse
      07-06-2012, 04:00 PM   #1
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
We strapped the F30 on the dyno today and did before and after runs for Burger Tuning's beta JB tuner for the N20 motor. The next step is to drive the car on the tuner and check for DTCs over the long run. For a first map the gains were solid: Apologies for the iPhone pic, but we shut the shop down early due to excessive heat.
      07-06-2012, 04:41 PM   #2
TreDirtyFive
Drives: X3 M40i
top end delta gains look great! 34whp and 24wtq out of a stage 1 4-banger. Thumbs Up.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      07-08-2012, 07:12 PM   #3
Mike@N54Tuning.com
BimmerPost Supporting Vendor
Drives: 2007 335i, 2015 M3
Nice gains out of the box! Is this with the new 6/20 firmware? Are you using the 3psi or 4psi setting?
Mike
      07-09-2012, 12:17 AM   #4
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
I'm looking forward to trying their n55 tune when it's available. Looking good
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      07-09-2012, 02:13 AM   #5
verbs
Drives: 2015 M235i
What's the deal with the car looking as if it lost power below 3200rpms?
      07-09-2012, 06:22 PM   #6
bugsandry
Drives: 2008 BMW e92 328xi
Is this tune available for N20 in 320i (Canadian version) as well? I have always wonder what's the difference between N20 in 320i and 328i since they are using the same base engine.
2012 BMW 328i Sport Line/Premium Alpine White - Current Car
2012 BMW 320i Alpine White - Retired
2006 BMW 525i Premium - Retired
      07-10-2012, 02:11 PM   #7
Mike@N54Tuning.com
BMS has not tested it yet on the 320 but is looking for a test car to do logs, and then they will send you firmware, etc. If you have one and are interested drop them an email.
Mike
      07-11-2012, 09:02 PM   #8
bugsandry
I am interested...However, first, do you know in terms of technical, what causes the difference in HP and Torque between 320 and 328?
Mike
      07-11-2012, 10:18 PM   #9
bananachipz
Drives: F30 Mineral Gray 335i
Can we move this to the proper section? Doesn't really belong in the N55 forum. Just sayin'
      07-17-2012, 09:14 AM   #10
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
I second that question. The graphs look like the car is running lean before it finally matches the factory afr AND it is losing both HP and Torque below 3,300. What is up with that?
      07-17-2012, 12:29 PM   #11
Mike@N54Tuning.com
The tuned run was started a few hundred RPM later than the OEM run.
Mike
      07-17-2012, 09:53 PM   #12
verbs
Drives: 2015 M235i
Mike
Why would you start comparative dynos at different rpms? It looks like both traps start at 2500rpms.
      07-17-2012, 10:30 PM   #13
jwickers
Drives: 328i GT
Great a graph without scale -> useless.
      07-18-2012, 08:47 AM   #14
mocohead
mocohead's Avatar
54
Mike
UM ok...that might explain the HP and Torque being below stock. How about the AFR?
      07-18-2012, 11:09 AM   #15
Mike@N54Tuning.com
AFR looks exactly the same as the stock runs. Stoich during spool by design settling down to high 11s by peak torque. AFR is mapped on boost so since the tuned run started a bit later it's AFR transition is shifted to the right slightly. Pretty basic stuff here guys. Seems you are over analyzing it.
Mike
      07-18-2012, 11:56 AM   #16
mocohead
mocohead's Avatar
54
Mike
Being condescending is not good sales practice. It is a surefire way to send potential customers to other vendors.
      07-24-2012, 08:27 AM   #17
jaxxx
jaxxx's Avatar
32
Drives: 440i GC
Looks like your over reacting
      07-24-2012, 04:33 PM   #18
Mahzari
Are my eyes playing a trick on me or is that more top end power? If so...
f30post
