E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > steering wheel buttons
      06-04-2012, 02:15 PM   #1
jonnyuk06
jonnyuk06's Avatar
26
Drives: 330d SE
i've tried searching for this question but coming up with a blank (more than likley because i'm not searching on keywords )
i have an se steering wheel and changing to an m-sport.
can i use my steering wheel buttons on the m-sport steering wheel, appreciate i need new trim
cheers
Driving....330d SE
Gone to the stealers (i want it back )....130i
Gone to the stealers....123d M Sport Coupe-BMWP 313 Alloys, BMWP CF Rear Diffuser, BMWP CF Spoiler, BMWP Black Grills, BMWP Pedals, Alpine Retrofit
      06-04-2012, 03:03 PM   #2
B005T3D-G
Class Leading Reprobate
B005T3D-G's Avatar
Scotland
15
Drives: Impreza STi - E92 335i (56)
Do you have the SE wheel with the triangular airbag or the Sport (not m-sport) wheel with the silver trim and round airbag?
If you have the sport wheel then it's a direct swap as the switches are built into modules and I believe you can still use the 'Sport' trim whereas the SE wheel looks like the buttons are built into slightly different modules and might not fit.
E92 335i | 6 Speed manual | BMS 4xLED Halo Bulbs | JB4 (waiting to be installed) | BMW Performance Gloss Black Grills | BMW Performance Exhaust | Smoked side Repeaters
Aero Front Lip | M3 Lip Spoiler |19" Cades Tyrus 'Gunmetal' with polished lips | Falken FK452 Rubber
........... More to come
      06-04-2012, 03:08 PM   #3
jonnyuk06
jonnyuk06's Avatar
26
Drives: 330d SE
i have the se wheel (not the sport).
the trim is different as is the airbag but the buttons look the same (if you remove the trim to reviel just buttons).
i'm hoping i can reuse the buttons, buy a the msport wheel, trim and airbag
cheesr
Driving....330d SE
      06-04-2012, 03:25 PM   #4
B005T3D-G
B005T3D-G's Avatar
Scotland
15
Ok, so here is your wheel. Note that there is no protruding button surround
This is the sport with the round airbag, note button surround
This is an M-Sport, note same button surround.
[/QUOTE]
If you pull your trim off and find the buttons in the same module then it should be a straight swap. If not then you'll have to source some buttons too.
*Borrowed pictures from around the site*
EDIT - Last pic is an M3 wheel I think but identical bar 'M' Button and non perforated leather hand grips.
      06-04-2012, 03:39 PM   #5
jonnyuk06
jonnyuk06's Avatar
26
Drives: 330d SE
Ah,see what you mean. Maybe the buttons are not a straight swap!
Driving....330d SE
      06-05-2012, 12:49 AM   #6
A_P
Drives: E46 M3
Listen to Boosted. Not MAYBE, They DEFINATELY will not fit.
      06-05-2012, 03:17 AM   #7
jonnyuk06
jonnyuk06's Avatar
26
Drives: 330d SE
Cheers for the info guys,time for olan b
Driving....330d SE
      06-05-2012, 04:31 AM   #8
A_P
Drives: E46 M3
Whats plan B?
      06-05-2012, 11:38 AM   #9
Tipper
Tipper's Avatar
9
Drives: 2007 E91 320d SE auto
I'm on the same quest but having stripped down both wheels and noted the incompatability of buttons between SE and my Sport flappy paddle replacement, will the latter's buttons work on the SE wiring without any modification?
I've still got the SE wheel on at the moment as I haven't plucked up enough courage to do the necessary wiring mods for the flappy paddles! I've got an awful feeling it may all go dreadfully wrong...
(It's also finding a day to myself without my wife wanting to go somewhere or use the car!)
      06-05-2012, 05:27 PM   #10
jonnyuk06
jonnyuk06's Avatar
26
Drives: 330d SE
plan B requires lots of money and begging to the wife to let me do it, that is to buy the bloody steering wheel!
not sure plan b will come off to be honest
Driving....330d SE
      06-06-2012, 12:40 AM   #11
A_P
Drives: E46 M3
there are a few M sport wheels around, coming with trim and MF buttons between 50 and 90 pounds delivered ( second hand, nice cond). All you need then is a round airbag. If your patient then you can do it at a relatively low cost.
      06-06-2012, 01:04 AM   #12
B005T3D-G
B005T3D-G's Avatar
Scotland
15
As long as the button lay out is identical I cannot see there being a problem. I doubt that they would change the pin outs on the connectors assuming they both share the same connector type.
It would be nice if someone else who has carried out the mod from SE to M-Sport wheel can chime in to confirm this as unfortunately at this point I am only making an educated guess.
      06-06-2012, 01:36 AM   #13
A_P
Drives: E46 M3
The MF buttons from the sport wheel connect directly in the slipring. So does the Airbag. So regardless of what steering you had first. As long as your Sport wheel has the Sport MF buttons fitted then these will connect directly into the Slipring connection behind the wheel.
It is very simple. One thing though if you are planning on removing your Airbag to check the wiring. PLEASE disconnect the battery first.!
      06-06-2012, 02:19 AM   #14
jonnyuk06
jonnyuk06's Avatar
26
Drives: 330d SE
i've been reading diy guides, seems a simple task. jsut need to source the parts now!
Driving....330d SE
      06-06-2012, 12:07 PM   #15
Tipper
Tipper's Avatar
9
Yes disconnect the battery and leave 15-20 minutes, so legend has it, before interfering with the airbag and its wiring. Having seen what an airbag does in an accident I wouldn't want one going off in my face whilst fiddling with the wheel.
Whilst discussing steering wheels and airbags it should be noted that the SE airbag unlatching method is subtley different to that for the MSport in that the SE requires a long thin screwdiver to be inserted into the wheel vertically and then levering the spring latches outwards (iirc or may be inwards, sorry bad memory these days) and the MSport simply has the screwdriver inserted horizontally to release the latch. There are a couple of threads that show this.
Additionally if you disconnect the airbag you will need to reset the fault light code every 'king time you do it even if you just refit the same airbag! It's a real PITA! BT kit required or a friendly garage with BMW 'puter.
e90post
