F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Best audio quality from Ipod/USB
ARMA SPEED
      05-29-2012, 08:23 PM   #1
Bmwphile
Bmwphile's Avatar
Australia
149
Drives: 2020 G20 330i
What sound format do you use for the best sound quality?
The standard default I tunes format produces only average sound quality in my standard sound system (9 speaker HiFi: Non Harmon Kardon).
I also found using Apple Lossless format, the quality is still inferior to the same music played on the CD.
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK
2012 F30 328i Sportline (Mineral Grey)
      05-29-2012, 08:34 PM   #2
ƒ°
ƒ°'s Avatar
101
Drives: ✚
The standard default I tunes format produces only average sound quality in my standard sound system (11 speaker HiFi: Non Harmon Kardon).
I don't know about the "best" sound quality, but I find that CD/wave files are good enough for my ears. But even those formats, I don't want to deal with the file sizes. So I'll have a couple CDs around that I know I'll appreciate when I itch for something with great sound. The rest are on my iPod... most of them being Apple lossless.
      05-30-2012, 11:10 AM   #3
PrazVT
PrazVT's Avatar
Drives: '21 M240i 6mt (soon)
FYI there is a reason it is called 'lossless'. FLAC and Apple Lossless and WMA lossless are bit perfect copies of wave files (cd or higher) The only limitation the iPod has is that it has a crappy DAC and can only do 24/48 Max.
I only mention FLAC as I use that format in home systems. Otherwise I use apple lossless for my car ipod as well. If you don't have enhanced USB, sound quality will suffer a bit.
      05-30-2012, 05:02 PM   #4
Bmwphile
Bmwphile's Avatar
Australia
149
Thanks PrazVT.
I don't have enhanced USB, but would I get any better quality using a USB drive instead of the IPOD?
BMWphile
      05-30-2012, 08:49 PM   #5
PrazVT
PrazVT's Avatar
In theory yes. The car's DAC should be nicer so music should sound cleaner. Assuming the same format limitations exist in the f30 as my dad's 09 335i, you can at least play wma lossless files (16/44 max resolution). I have a decent amount of hi res music (24 bit) so I will have to downsample those tracks - but everything will be at least CD quality and a digital transfer to the head unit.
I am going to do a little A/B testing this weekend on the 335 again to see how my 24 bit music on the ipod sounds vs 16 bit via USB. I'll report back..
      05-31-2012, 06:56 AM   #6
Bmwphile
Bmwphile's Avatar
Australia
149
Thanks PrazVT. I look forward to hearing of your results!
BMWphile
      05-31-2012, 03:56 PM   #7
PrazVT
PrazVT's Avatar
Sure thing - will update you guys on this on Saturday. I also have another idea ..but I need to check a few things first.
- Praz
      06-02-2012, 02:00 PM   #8
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
How do you use Apple Lossless on your iPod? I went through iTunes and cant find anything.
      06-02-2012, 10:25 PM   #9
Bmwphile
Bmwphile's Avatar
Australia
149
When you rip from a CD in ITunes, there is a button for "import sttings" set this to "Apple Lossles encoder"
BMWphile
      06-19-2012, 03:00 AM   #10
PrazVT
PrazVT's Avatar
yeah or if you are converting from flac you can use dbpoweramp. thus far my f30 isn't able to play wma lossless like my dad's e9x, not sure why. Plus BMW didn't include the iPod adapter. thankfully I just remembered I copied my mp3 80s and classic rock mixed folders to the ssd so we will have some tunes. I am going to experiment a bit tonight when we get to Vienna. Otherwise I have to say the HK system sounds noticeably better than my dad's Infinity/hk system.
      06-19-2012, 11:30 AM   #11
funkahdafi
funkahdafi's Avatar
Germany
70
Drives: Z4 (E89) sDrive 35is
The human ear is not capable to hear a difference between 24 and 16 bit, let alone 44 vs. 96 khz.
      06-19-2012, 12:21 PM   #12
gerbs
woof
gerbs's Avatar
Drives: M6
For what it's worth, I notice a significant difference on the M3's Individual High End Audio system when playing music from a usb hard drive vs. the aux jack.
Sounds obvious, but I didn't realize it until hearing the same songs both ways. I believe playing thru USB (or iPhone, iPod, etc.) preserves the digital output whereas the aux jack translates digital to analog.
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      08-22-2012, 10:39 PM   #13
Bmwphile
Bmwphile's Avatar
Australia
149
Apple Lossless won't play through a USB drive (Although it is okay through the IPOD). So will FLAC & WMA lossless play through the USB?
Thanks for your help.
BMWphile
      08-23-2012, 12:11 AM   #14
PrazVT
PrazVT's Avatar
FLAC won't play over USB in any BMW. WMA lossless (16/44) plays fine in my dad's '09 335i over USB, but it doesn't work in my f30. I'm not sure why - may be something to do with having navigation or enhanced usb?? Wave files should play fine though.
Maybe you guys with nav and/or bmw assist can give it a shot.
f30post
