TX: Brand new in box reverse hid kit
05-15-2012, 03:45 PM | #1 |
Rep 42
Price: $55 or best offer shipped. Also trades accepted looking for a harddrive Payments accepted: Paypal or cash money if local Contact information: pm Is the item new or used: New Reason for sale: Spare kit I had laying around. ----------------------------------------------------- Product description: Super bright 15W HID reverse lights made from polymer shell resulting in excellent heat dissipation. This HID back up reverse light (HID reverse lamp) is the latest advanced technology of car lighting, also displays the brightest lumens output for reversing. This product can be used on back fog light or stop light as well as reversing light. It emits 4 times of light than original halogen bulbs with the same power consumption. It will give you greater sight when reversing your car! - Easy installation - More brighter than $50+ leds - More safe for parking at night - No need for Relay Harness (Only 2A to operate the 15w HID) - Perfect for people with dark tint - Safe for plastic housing, its only 15w vs. regular 35w plug and play kits. Specifications: 1. Input Voltage: 9-16V 2. Normal Current: 2.0A 3. Output power: 15W 4. Working Temperature: -40 - 50 degree 5. Color temperature: 6000K (super pure white) 6. Start Time: 90% in 3's 7. Restarting more than 500,000 times no fault 8. Luminance: 2500LM 9. Base: T10/T16 Includes: 2 x 15W Plastic Waterproof Ballasts 2 x 15W HID 6000K Bulbs with Ceramic Base 2 x Ballast Input Extension Cables 4 x Bulb Housing Adapters 2 x 1156 Bulb Wiring Adapters 2 x 7440 Bulb Wiring Adapters 2 x T10 (194/168 ) Bulb Wiring Adapters 2x 3M Double sided foam mounting tape 1 x Retail box 1 x Owner’s manual The following bulbs can be replaced with this HID kit: Fits most vehicles P13W / 5502 H16 / 5202 1057 / 1157 1057 / 1156 3057 / 3157 / 3357 3056 / 3156 / 3356 7507 / 7506 921 Photos: Last edited by ek9cv5; 05-15-2012 at 04:01 PM.. |
05-15-2012, 04:07 PM | #2 |
2007 335i E92
44
Rep 624
damn, those are interesting.. anyone sporting these on their 3er and have pics to share? any heat issue?
2007 335i E92 AT - MHD E85 Flash, xHP Stage 3 , MR5 Intake, VRSF DPs, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, BL R8 Coils, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, CF Hood, Mini Battery :: 2011 X3 xDrive 35i - MHD Stage 1, Alum Charge Pipe
05-15-2012, 04:42 PM | #3 |
Rep 2,009
im curious how these work on a 3 as the reverse bulb is installed into a Cap that then twists into the hole of the taillight, not the bulb just twisting into a socket.
and since there are wires coming out the back, dont see how it can go into the cap. do you have this installed on your 3? |
05-15-2012, 04:43 PM | #4 |
Rep 2,009
just wanted to post the answer to my own question as i do not want possible buyers to be turned off by my questions.
i found this kit on ebay, and it looks like it has changeable orange caps that will allow it to fit into the housing http://www.ebay.com/itm/15w-universa...ht_1056wt_1396 so i would assume this has the same Last edited by JYohay; 05-15-2012 at 04:51 PM.. |
05-16-2012, 01:35 AM | #8 |
No 55mph
1622
Rep 8,476
This kit is for the Reverse, or Back-up lights. The Rear Fogs do not use the reverse bulbs in our cars - so it's not going to make the rear fogs any brighter...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
