Help! 335 cab stereo gone mad
05-08-2012, 11:09 AM | #1 |
Rep 451
We have a 2007 335 convertible and the audio system has gone haywire.
It makes a loud cracking/shorting out noise through the speakers, even when the engine is switched off. It sounds like it is shorting out. Its fitted with factory fit BMW sat nav/tv has never given any problems before now. Question 1 - how can I cut power to the stereo as he can hardly even drive the car with this noise coming out the speakers (before we take it to the local car audi specialist to look at). Question 2 - what could cause this on such a nice new car? |
05-08-2012, 11:24 AM | #2 |
Rep 3,969
First place I would look is in left hand corner od trunk where the amp is mounted (if you have an amp). There should be a gray panel you can pop off and the amp is under it. Look for water...
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-14-2012, 05:51 AM | #3 |
Rep 451
They've had a look and the amp has got water damaged so need another one.
The part number is 65-12-HV 9145 162 PLT Hi Fi Verst Lear Corp does anyone know where I can get one outside of having to use BMW? does the part number have to be exactly the same to work as I have found one on ebay part number is 3 digits out? |
