Which setup is better? Desperately need expert help!
04-25-2012, 05:31 PM | #1 |
Rep 5,623
Hi
I am considering two upgrades to my existing system and really want some of your thoughts on each one. Currently i have the ms-8, with a vibe slick 4 as the centre channel, hooked up in my base system. all speakers apart from the vibe are stock. i now want to add components and a 4/5 channel amp powering the components and woofers and maybe the centre vibe. 1st setup For this option i would add an alpine pdx-f6 which would give me 150wrms x 4 @ 14.4 volts (so a bit less at 12.5v). I would also add morel dotech ovation II 4" components which are rated 100wrms but i think would be happy with a bit more power this amp will give. the other two channels would be turned down a little to give roughly 80w rms to my stock 6.5" woofers (like the oem alpine upgrade). The centre channel and rears would have to be left to ms-8 power. 2nd setup For this setup i would add a jl xd600/6 which would give me 60wrms x 6 @ 12.5v. So a lot lower/channel than the alpine. I would have to get some different components that are rated at 50wrms (focals/rainbows not really sure) which would have a channel each. the underseats would receive a little less power at 60wrms each. The centre vibe would be powered nicely by 60wrms. the last channel i would leave disconnected and the rears would be left to the ms-8. So these are my two options. The first set up will give me better quality components, more power but my centre channel will be on ms-8 power. I dont think this will be too much of a problem it should still be audible? not saying that this will definately happen, but personally i dont really like a narrow front stage. The second setup i will have the front 5 channels all amplified but with less power and lower quality components. i may be wrong. My gut feeling is to go with the first option as a) it has more power (and headroom which is good?!) and better quality components and b) IF i upgrade woofers at a later date, the alpine would have sufficient power for them. I would be really interested to hear what u guys think of these two set ups. |
04-25-2012, 06:03 PM | #2 |
Rep 5,120
I'd go with the morels and xd 600/6. Your voltage should be around 14-14.4 with the car on so it's a little more power than your calculating. Anyways you'll never turn up the volume enough to use all that power unless you want your ears to bleed.
04-25-2012, 07:19 PM | #3 |
Rep 13,104
Not sure why your changing speakers with amps
Most people here would call the Jl xd a better and its used here more often. I would go with Morels over Focals because they are noted to be less harsh (if they fit they don't fit in the coupe) I would consider upgrading the under seats with something that can handle the power better and sound less muddy though they will sound better with more power(you might blow them to). The weak points you have now are the under seat speakers (underseats are both small cheap and underpowered) and not really a lot of power if you upgrade the doors. Last edited by ctuna; 04-25-2012 at 07:27 PM.. |
04-26-2012, 09:07 AM | #4 |
Rep 5,623
I am going to upgrade the woofers but in due course.
I prefer the morels too. the reason why i dont want the jl xd with the morels is i think the morels will be better with more power. they are rated 100wrms and i dont want to bridge as underseats will be underpowered then |
04-26-2012, 10:26 AM | #5 |
Rep 740
The Morels sound fantastic with the JL600/6. No need to worry about them being under-driven.
In fact, because they are direct line-of-sight to your ears (rather than down by your ankles), they are plenty loud and I can't imagine wanting to go with more amplifier. The same JL600/6 will drive the underseats quite well, and will still have enough power if you upgrade to Jehnert/SWS8. |
04-26-2012, 10:27 AM | #6 |
Rep 13,104
I have that setup
I have that setup
I can turn it as loud as I want it. Which I would characterize as moderately loud . Loud enough that I can drown out the air noise with the Windows open. I don't have the under seats bridged and the bass is plenty loud. But I am not trying to rattle the frame bounce the car or the ground and I am not a bass head. Dotechs front doors and Jehnert Floors. no bridging |
04-26-2012, 02:58 PM | #7 |
Rep 5,623
so the general consensus is going for the xd. well having the xd does give me the advantage of having a channel for the centre. I just assumed that 60-75wrms wasn't enough for aftermarket/oem woofers and the morels and the xd would be strained. but from what you guys are saying it should be fine.
So what are your reasons for choosing the jl xd over the alpine? Because you're right, they must sound really good with the xd, but im thinking they might sound even better with the alpine or a higher powered amp: I've had someone telling me to go with a Soundstream Reference amp. These are class A/B and i think better quality? Assuming that this amp is 115wrms x 4 and the same physical size of the xd (which of course they are not), wouldn't this be a better choice? |
04-26-2012, 03:10 PM | #8 |
Rep 13,104
I was reluctant to go class D
I was reluctant to go class D, it took me awhile to go to CD's to.
But the xd sounds very good responds well across the entire frequency range. You could also get one or two of the higher power JL's I hear the HD Series wins car shows. If you are going to go for class AB consider a Zapco The more exotic amps are not as well reviewed an it starts to get into the boutique custom electronics area not to mention the cost. The Jl's accept the balanced inputs from the stock head unit no questions asked they are small and compact and in the case of the xd fit perfectly in the stock location and have the exact number of channels( xd 600/6 )for a Hi Fi replacement. This may not apply to you if you already have an ms-8 . Jl is very well regarded in the US. If you have the room for an amp with more power and the money to get by all means go for it. Its the old question of price performance. Last edited by ctuna; 04-27-2012 at 02:17 PM.. |
04-26-2012, 03:27 PM | #9 |
Rep 5,623
Thanks for your input
I have considered the HD series but they are too expensive for me I have the base system (not hifi) and the ms-8 so i suppose the balanced inputs aren't an issue for me. Regarding space, i will gladly give up a little space for a class A/B if it means a huge performance increase. I will have a look at zapco amps as well. I get what you're saying about price performance. The cheapest i can get a JL XD600/6 is £360 ($580). The cheapest i can get a Soundstream Reference 4.760 is £310 (this will be ordered from america and includes all shipping and taxes). So if the Soundstream is a better quality amp AND its cheaper (although I will have no warranty as im in the UK) then i suppose its a no brainer to get it? |
04-26-2012, 03:35 PM | #10 |
Rep 13,104
Some people mention they like those Soundstreams
But they are usually people that have been around here a long time as that was an amp that was popular before the full range class D's were out. So you are going to have to get some of the veterans to chime in on that and do some searching. |
04-26-2012, 08:19 PM | #12 | |
Rep 6,845
Drives: 2018 Audi RS5 coupe
No the Soundstreams that rocked was back when it was a US owned company with the amps made in the states When the company was sold, the quality went downhill I've heard a few positive reviews of the new stuff but i haven't tried them myself I had JL xd600/6 xd700/5 and currently xd600/1 Great amps I can't think of a better value amp out there
04-27-2012, 05:59 AM | #13 |
Rep 5,623
ok the soundstream idea has been binned....
wow, around 80% of the posts ive read would take the xd over either of the alpines, f4 or the f6. ive read other threads on diyma etc, and most ppl reccommend the xd. is this because everyone got off the old pdx's cos of noise issues and got jl's? as i think the new ones must surely be better? the F6 has been on various threads as a comparison to a JL HD. So surely it must be better than a XD? i just cant get my head around buying an amp which has about half the power, a lower damping factor, a narrower frequency response and a lower singnal/noise ratio. Ive read somewhere that these factors are important to class d amps. the only positives i can see in the XD is that i get one 2 more channels and its smaller; but these aren't important to me |
04-27-2012, 10:27 AM | #15 | |
Rep 6,845
amps do sound different, and specs don't tell you everything some people swear by tube amps, even though, spec wise, they don't compare to modern amps.
04-27-2012, 11:32 AM | #16 |
Rep 13,104
The only thing JL does is amps and speakers
So that is there area of concentration. They are noted to under spec there
product and considered more honest about what they put out . I would suggest you visit there website and zapco's website. Try to find some reviews on cnet or some of the technical review sites. |
04-27-2012, 01:32 PM | #17 | ||
Rep 5,623
1) If i decide to bridge some XD channels. How would i wire it up so that say the ms-8 channel 3, which is currently my left woofer, goes into the xd and comes out bridged? Would i wire an rca from the ms-8 channel 3 into the channel 1 XD input, leave channel 2 XD input blank, and then id be able to bridge the channel 1 nd 2 output? Then for the right side woofer, do the same but use channel 3 XD input and bridge the 3rd and 4th output? I'll just bridge if i feel the morels or woofers feel underpowered, but from what you guys are saying it should be fine. 2) Will the XD fit under the boot floor, on the left hand side of the bluetooth module? 3) Does the ms-8 do everything on externally amped channels except amplify them? |
04-27-2012, 01:35 PM | #18 |
Rep 5,623
Ok thats good news, i just assumed that the amp would be getting around 12.5 volts.
04-27-2012, 01:44 PM | #19 |
Rep 5,623
Would you put the PDX-F6 in this scenario, if you had the choice between XD600/6 and the PDX? As in, do u consider the pdx-f6 to be a better performer?
04-27-2012, 02:03 PM | #22 |
Rep 13,104
The xd is a perfect fit for the stock location
The xd is a perfect fit for the stock location.(minus the amp rack)
From the systems I have seen right here in the audio upgrade section. The ms-8 can go next to the TCU and the amps usually go in the the stock location. Some people add the cd player storage kit then they can get a couple of pieces in that location. There are multiple examples of an ms-8 plus amps in all the system examples in the stereo http://www.e90post.com/forums/showthread.php?t=641323 I haven't bridged on the XD but you can download there manual from the site . I kind of remember you might need Y Rca adaptors for the Inputs to make the bridged configuration work. Last edited by ctuna; 04-27-2012 at 02:14 PM.. |
