New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      04-22-2012, 02:39 PM   #1
SpeedDemon7
SpeedDemon7's Avatar
70
Drives: 2015 F80 M3 Austin Yellow
e89 Coding Options?
I was wondering if anyone had a link or knew any of the possible coding options for the e89. I have done some research but found nothing. As far as for the coding options, I am talking about the ability to change certain default options, such as enabling top to close when rain sensor is activated, or making the alarm light under the rear view mirror blink even if you do not have the factory alarm equipped, also changing some of the welcome lighting options. There is a whole list of option available for the e90/e93 (2007+ 3 series). Just wondering if any of the options are available on the e89.
      04-23-2012, 03:26 AM   #2
ManiacGT
ManiacGT's Avatar
Drives: Z4 sDrive 35i
There's nothing about an auto-close roof that I'm aware of. It may be considered a safety issue. In any event, I would suggest speaking to a BMW Specialist or BMW Dealer as they are likely the only people with a definitive list of what can be done. Obvious really.
      04-23-2012, 02:38 PM   #3
wdlfbio
Drives: 2013 4S, 2015 3500 HD Dually,
When I coded my 335 and M, I noticed to a of options that were not available on either model. I bet you can find the same things under the same ECUs, but I don't know of you'd actually select E89 in NCS Expert or not. E89 I what we use for E9x. I'll find out when we get ours back from Munchen in August...
'16 235i
'15 3500 HD Dually
'13 C4S
      04-25-2012, 09:37 PM   #4
GaryRudolph
Drives: 2012 Z4 sDrive35is
I've had success with most of these, but NCS Expert and the right v files re a pain to get.
2JBFF or JBFF
ZYCLUS_VOLLEND_KLR_AUS: nicht_aktiv -> aktiv (Wipers go to flat when turned off)
CAS
KOMFORT_EJECT: nicht_aktiv -> aktiv (Ejects Key with Engine Off)
ER_KEYOUT_AUTOVR: nicht_aktiv -> activ (Unlocks Door)
KOMFORTSCHLIESSUNG_FB: nicht_aktiv -> aktiv (close windows and sun roof with Key)
CIC
LEGAL_DISCLAIMER_TIME: ld_mit_timeout -> kein_ld (Remove Navigation Warning)
RADIO_WEATHERBAND: nicht_aktiv -> aktiv (Add Weather Band)
NAVI_MAPMODE_AUTOMATIC: nicht_aktiv -> aktiv (Turns on night/day detection for Nav)
FBM_SELECTION: six_buttons_us -> eight_buttons (NO…. Allow 8 buttons to be programmed)
KOMBI
BC_DIGITAL_V: nicht_aktiv -> aktiv (Onboard Speed Display)
BC_DIGITAL_V_KORREKTUR: aktiv -> nicht_aktiv (Remove digital speed correction)
NFRM or FRM
DOPPELBLINKIMPULS_WARNBLK: nicht_aktiv -> aktiv (Double blink)
ASP_KOMFORT_EINKLAPP: nicht_activ -> activ (Fold Mirrors with key fob)
      04-26-2012, 11:52 AM   #5
SpeedDemon7
70
Nice, For the sunroof close with key fab, I am assuming this would be with the top right? Is it posible to be able to put the top up going >20mph?
      04-26-2012, 01:22 PM   #6
GaryRudolph
No, still have to be stopped for the key to go up/down. You need SmartTop to fix that.
      04-26-2012, 01:54 PM   #7
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [10.00]
search e90 section, there are plenty of coders there
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
zpost
