Logic7 upgrade: SWS-8 and/or 10” or 12” JBL GTi
04-20-2012, 12:16 PM | #1 |
Rep 197
I recently picked up a 2009 e90 with Logic 7 stereo and the low-end is lacking. I’m used to ripping out the entire stock system and starting from scratch with a head unit, amps, front stage and subwoofer, so this setup is pretty new to me as I’d like to keep the stock looking appearance and use the current controls. I prefer SQL systems and think the high-end is decent right now, though I may think otherwise once I install some low end. Some questions:
Thanks for your help! |
05-21-2012, 06:14 PM | #3 |
Rep 4,121
Have you looked at:
http://www.e90post.com/forums/showthread.php?t=420444 |
05-21-2012, 06:17 PM | #4 |
Rep 4,121
Thanks for your help![/QUOTE] |
05-22-2012, 06:42 PM | #5 | |
Rep 213
Thanks for the reply! Lot's to read and consider.... |
05-22-2012, 07:19 PM | #6 |
Resident Car Audio Guru
Rep 597
OP - if you're used to full tilt high-line systems there are several things you can do to improve on the factory system. To start, I think you would be happy with better 8"mids in the factory location. If you don't want to spend the money for that, then just send the factory mids more power. They'll do well with 100rms of clean power.
Upgrading the factory amplifier, and adding a processor will improve the sound quality exponentially. I do not like the factory tweeters. I'm not a fan of metal tweeters. Replacing them with something from Morel (like the MT-22 or MT-23) will do wonders for improving the imaging and the sound stage. Replacing all 5 mids will multiply that improvement. Changing the underseat midbass is not, necessarily, mandatory to improve low-end response, since they are placed well enough that you dont' need huge amounts of bass to feel it. Consider just adding power to them. Essentially, you can spend a little, relatively, or a lot. It depends on your budget, and requirements for your opinion of good sound. Once you have a budget in mind we can go from there. You don't have to do everything at once. Do it piece by piece, and spend money on each part ONCE, rather than doing it all, then having to do it again.
05-22-2012, 09:33 PM | #7 |
Rep 197
This thread is pretty old now. I've almost got my system planned fully. Just working on a couple more details (which components and processor; have another thread for this actually lol). I appreciate the time and responses.
