06-19-2007, 02:41 PM | #1 |
Rep 2,486
Hydrolic Bleeder on trans?
Is there a bleeding point in the hydrolic line anywhere near the transmission. My clutch feels like there might be an air pocket somewhere in the line..
06-19-2007, 02:52 PM | #2 |
My favorite sign.
167
Rep 4,333
Weird...the only thing that comes to mind is the CDV.
06-19-2007, 03:23 PM | #4 |
Rep 2,486
where is that located. Right after the CDV
06-20-2007, 01:12 PM | #5 |
Rep 155
If i not mistaken, the clutch is self adjusting if you have been doing some hard launches you may have a few flat spots that will even out over time
06-22-2007, 01:55 PM | #6 |
Rep 60
It's on the slave cylinder, not on the tubing. If you know what a bleed nipple looks like you can't miss it.
Bubbles go up and the slave is at a relatively low point in the system so unless you break the line or want to flush the system you shouldn't need to bleed. |
06-22-2007, 02:55 PM | #7 |
My favorite sign.
167
Rep 4,333
Isn't the clutch on a 3.0 different than the M?
06-22-2007, 04:51 PM | #9 |
My favorite sign.
167
Rep 4,333
Artz...this might be helpful since the ZM has more components in common with the M3 than the Z.
http://m3.madrussian.net/diy_brake_bleed.shtml If that doesn't help I'd ask zeckhausen about it.
