Automatic Audio Leveling
04-11-2012, 10:47 PM | #1 |
Rep 146
Ive searched to see if anyone else has this issue. When I am driving the radio volume increases to a point where its distortated and was wondering if there is a way to turn that feature off? Ive also looked in the manual and do not see anything.
04-12-2012, 06:12 AM | #2 |
Rep 63
I believe it is called speed compensation, or something with speed in its name, so search for that in your manual. Will likely be in the audio adjustment type section. My 06 e91 with idrive has this feature and it can adjusted in the same menu as the fade/balance/bass/treble. So if you do not have I drive, the first thing I would do is look around in that audio adjustment.t section that allows you to change the fade etc.
04-12-2012, 06:49 AM | #3 |
Big Beaver Smile
2101
Rep 3,791
Look up "speed volume" in your manual. It's kind of sketchy the way it's worded, but after you find it in your settings, set it to a lower number and it won't go up as loud.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
04-12-2012, 10:36 AM | #4 |
Rep 146
ok great. I will check it out, its one of those annoying things-also I checked the fader option but mine doesnt have it, I dont have the iDrive neither.
04-12-2012, 11:28 AM | #5 |
Big Beaver Smile
2101
Rep 3,791
I thought every car with a radio had a "fader". I can not say 100% for sure because I always get idrive and upgraded sound, but a fader and balance has to be there somewhere in the settings. look in your book again when you're looking up the speed volume. Good luck!
04-12-2012, 12:55 PM | #6 | |
Rep 146
04-12-2012, 09:16 PM | #7 | |
Rep 6,845
Drives: 2018 Audi RS5 coupe
Then you get s-vol and gong
